Using check_domain
trungleviet
Using check_domain
Post by trungleviet »
Dear all,
I am using Nagios Core 3.4.1. I read about check_domain command on http://exchange.nagios.org/directory/Pl ... in/details
I add this plugins and could use id for monitoring some my domain names (03).
check_domain -d domainname -w 60 -c 30
Now, i would like to use this plugins for monitoring a larger number of domain names (about 1500 domain names).
I need to do one by one for this large number of domain names?
Could you please advice me how to do this task?
Many thanks for your supports,
Trung Le Viet
yancy
Re: Using check_domain
Post by yancy »
Trung Le Viet,
Your best bet is to write a shell script to create the required .cfg files
We do have a bulk import wizard which can be used with NagiosXI.
Regards,
-Yancy
trungleviet
Many thanks yancy, i will try will bulk import wizard
Thanks for your advice,
Trung Le Viet
