Error Trying to add Repo
Post Reply
dancormack
Post by dancormack »
I am trying to install the Nagios repo on a server hosted in Oracle Cloud Infrastructure. I am receiving the following error:
sudo rpm -Uvh https://repo.nagios.com/nagios/9/nagios ... noarch.rpm
Retrieving https://repo.nagios.com/nagios/9/nagios ... noarch.rpm
error: Failed dependencies:
rpmlib(PayloadIsZstd) <= 5.4.18-1 is needed by nagios-repo-9-1.el9.noarch
Can you please identify the steps required to correct this so tha tI can install the NCPA agent? Thanks!
jmichaelson
Re: Error Trying to add Repo
Post by jmichaelson »
What is the output of running
rpm -q rpmlib
-Jason
dancormack
Hi! I get this:
package rpmlib is not installed
I guess I need to know how to install this, ensuring it's whatever version is needed etc.
bbahn
Post by bbahn »
Hello @dancormack,
per https://community.oracle.com/customerco ... positories
1) If the package is not already installed in the system, use:
sudo yum install --downloadonly --downloaddir=. package-name
This will download the RPM and any needed dependencies to the local directory.
jmichaelson
Try running yum install rpmlib
-Jason
Post Reply
