GCP & AWS Cloud Monitoring
Post Reply
nishith.vyas
Post by nishith.vyas »
Hello Nagios Core Monitoring Experts,
I've been working on Nagios Core 4.x for more than 7 years & as per my current assignment, I've been instructed to setup a pilot project to monitor "advanced level cloud service parameters" as stated below.
  • All kinds of Load Balancers (Application, Gateway, Network LBs)
    VMs/GCP Compute Engine/AWS EC2 Instance monitoring parameters
    Attached Local block storage
    Cloud Object Storage (Like AWS S3 Bucket)
    Instance level firewall Rules (Like AWS Security Group Rules)
    VM/Instance automated horizontal scaling feature (AWS Autoscaling)
    VPC Monitoring
    SSL Certificate Monitoring, deployed on the cloud load balancer
    VPN Tunnel Monitoring (Site to Site VPN)
    PaaS Service Monitoring (PaaS MySQL/PostgreSQL/Oracle Database mostly)
    Serverless monitoring (RedHat OpenStack/OpenShift on Cloud)
    Any prompt response is highly appreciated on this matter as I just need to have a "execution point to start".
-Nishith
bbahn
Re: GCP & AWS Cloud Monitoring
Post by bbahn »
Hello @nishith.vyas,
If you would like personalized assistance from Nagios in setting up your server, you can create a case here: https://answerhub.nagios.com/support/
nishith.vyas
Is the community login work with the provided link?
I tried but didn't work. Do I need to get a paid support for the same?
-Nishith
gwesterman
Post by gwesterman »
Hi @nishith.vyas,
You will need to first request answer hub access. The link to do so is at the top of the form @bbahn linked you. Once you fill that out, you will get credentials and you can log in and create a case.
Let us know if you need anything else.
Thank you!
nishith.vyas
Dear gwesterman,
I did follow the same steps however it is asking the license keys. Refer attached screen shot for more information.
FYI: I'm using "Nagios Core" to achieve the cloud testing environment.
Kindly Check,
Nishith N. Vyas
jsimon
Post by jsimon »
Hi Nishith,
It sounds like you might want to get in touch with our sales department. Our standard AnswerHub support process does not include implementation support, so even with a support plan I don't believe that would be the right next step for you. I would recommend reaching out to [email protected] so that we can put you in touch with our Partners team to get you the assistance you are looking for through the proper channel.
Post Reply
