Problems with nrpe and nagios console
aquegles
Post by aquegles »
Hi there, im having some problems with the nagios web console and nrpe, hope you can help me with this...
I have installed and running the nrpe daemon and nagios plugins in a HPUX server. In nrpe.cfg i have the following command definition :
command[check_hpux_disk]=/opt/nrpe/libexec/check_disk -w 20 -c 10
In my nagios server i run this command :
/usr/local/nagios/libexec/check_nrpe -H 130.0.200.111 -c check_hpux_disk
and it returns correctly, like this : OK - DISK usage ( this is an custom command i wrote )
i have added the following line in my remotehosts.cfg file in nagios server :
        use                             generic-service         ; Name of service template to use
        host_name                       Desarrollo
        service_description             Root Partition
        check_command                   check_nrpe_1arg!check_hpux_disk
and the definition of check_nrpe_1arg in the commands.cfg file is :
command_name check_nrpe_1arg
command_line /usr/local/nagios/libexec/check_nrpe -H $HOSTADDRESS$ -c $ARG1$
But in my nagios console, the service appears with violet color, and displays the error "The check_nrpe plugin returns "CHECK_NRPE: Received 0 bytes from daemon. Check the remote server logs for an error message."
Why this is happening??? can anyone please help me???
Thanks a lot!!!!!!!!!!!
Re: Problems with nrpe and nagios console
Post by slansing »
This could be due to the lack of correct arguments for the check, could you:
tail -f /var/log/messages
