is it possible to uninstall Nagios
benhank
Post by benhank »
Is it possible to uninstall nagios without reinstalling the os?
I tried to doc "uninstalling nagios" but when i ran the command:
[root@lkennagiosxit01 ~]# /usr/local/nagiosxi/scripts/uninstall-xi.sh
So then:
[root@lkennagiosxit01 ~]# cd /usr/local/nagiosxi/scripts/
[root@lkennagiosxit01 scripts]# ls
[root@lkennagiosxit01 scripts]# ./uninstall_xi.sh
i got:
-bash: ./uninstall_xi.sh: Permission denied
I understand that nagios has to be installed on a fresh install of centos, but will this script restore it to the "fresh, never been installed" state?
I ask this because on our test server, sometimes we want to do projects from a fresh start, but reinstalling the OS is not always an option, as my servers are 50+ miles away from where my office is.
Re: is it possible to uninstall Nagios
Post by slansing »
That is a permissions error run the following:
chmod +x /usr/local/nagiosxi/scripts/uninstall_xi.sh
This script is a beta though, so please let us know if it works out for you.
benhank
Post by benhank »
nah I did not work. to many linux commands for a person on my level to edit. too bad tho. guess I gotta hop in the car.. =(
Proudly running:
Nagios Network Analyser
Nagios Fusion
Post by slansing »
What did the terminal tell you when you tried to run the script again after making it executable?
ockmeyer
Post by ockmeyer »
I don't see a response to the questions, but this is what I get after making the file executable:
/usr/local/nagiosxi/scripts/uninstall_xi.sh: line 4: ./init.sh: No such file or directory
Post by slansing »
Make sure you are running it with a ./ in front, to make it easier do this:
./uninstall_xi.sh
ockmeyer
Post by ockmeyer »
I'm trying to run it exactly like that and still get:
./uninstall_xi.sh: line 4: ./init.sh: No such file or directory
ockmeyer
Post by ockmeyer »
Has anyone figured out how to get the uninstall script to run?
Try this one instead:
uninstall_xi.sh
Note: This *should* uninstall Nagios XI, but it will also uninstall MySQL and PostgreSQL.
Let me know if this worked for you.
benhank
Post by benhank »
I started the thread, so I will be the first to boldy go where no >insert gender neutral politically correct word here< gone before! ...coughonmytestservercough =K
Proudly running:
Nagios Fusion
