Nagvis integration
BanditBBS
Nagvis integration
Post by BanditBBS »
I have NagiosXI 3.3 installed and wanted to check out NagVis.
I downloaded the component and installed it. I did modify the script so it would install NagVis 1.7b3. The script ran fine except for the line regarding the automap as in 1.7 the automap has been removed. I can login to nagvis but it seems as though I am just logged in as a normal user. How do I login to it as an admin as the default user/pass of admin/admin does not work when installing using the Nagios script. I don't seem to have any configuration options is why I say I am not logged in as an admin.
Jim
2 of XI5.6.14 Prod/DR/DEV - Nagios LogServer 2 Nodes
See my projects on the Exchange at BanditBBS - Also check out my Nagios stuff on my personal page at Bandit's Home and at github
BanditBBS
Re: Nagvis integration
Post by BanditBBS »
