3.2 -> 3.3 Upgrade Errors?
scrantic
Post by scrantic »
Hi Guys, Just making sure that the below errors encountered during our upgrade are not an issue?
Installing new PNP templates...
Updating init script...
Enabling large install tweaks...
Fixing config file permissions...
Fixing htpasswd permissions...
Checking group memberships...
Stopping httpd: [FAILED]
Starting httpd: (98)Address already in use: make_sock: could not bind to address [::]:80
(98)Address already in use: make_sock: could not bind to address 0.0.0.0:80
no listening sockets available, shutting down
Unable to open logs
[FAILED]
yancy
Re: 3.2 -> 3.3 Upgrade Errors?
Post by yancy »
scrantic,
Is HTTPD running and accepting connections after the upgrade?
service httpd status
regards,
-Yancy
scrantic
Post by scrantic »
Yeh, All seems to be running OK just don't want to get stung in a week or month and find that something was missing :).
mguthrie
Post by mguthrie »
Yeah, I think you're ok. We have the upgrade script halt if there's a critical error that it encounters.
