How to find if agent is successfully installed on AIX server
srikanth.kallu
Post by srikanth.kallu »
I am trying to install agent i have got this error
Can i get help in this
# ./fullinstall
Nagios XI AIX Agent Installer
This script will do a complete install of the Nagios XI
AIX agent by executing all necessary sub-scripts.
IMPORTANT: This script should only be used on a AIX
system. Do NOT use this on a system running
any other operating system.
Do you want to continue? [Y/n]Y
Proceeding with installation...
Current step is 0-prereqs
Running './0-prereqs'...
RESULT=0
0-prereqs appears to have already completed successfully. Moving on to the next step.
Current step is 1-usersgroups
Running './1-usersgroups'...
RESULT=0
1-usersgroups appears to have already completed successfully. Moving on to the next step.
Current step is 2-plugins
Running './2-plugins'...
package nagios-plugins-1.4.16-1 is already installed
RESULT=1
INSTALLATION ERROR!
in your communications with Nagios XI technical support.
The script that failed was: './2-plugins'
Re: How to find if agent is successfully installed on AIX se
Is this on the AIX 7.1 server?
srikanth.kallu
yes,
Nagios works alright on one of my aix 7.1 server which i first installed.
And not on all the remaining servers.
If possible i would like to clean up every thing and start from the scratch.
Lets try this on this server since it says the plugins are already installed
cat /dev/null > ./2-plugins
./fullinstall
srikanth.kallu
Can you please provide me the full path of install.log
Post by slansing »
It should be located in the install directory where you unzipped the tarball.
srikanth.kallu
This is an aix server when i try to install agent on this i got his message " Nagios XI AIX Agent Installation Complete!"
But i found NRPE is still not running.
I have attached the logs.
Can you please help.
Post by slansing »
Can you run this and post the output here:
/usr/local/nagios/bin/nrpe –c /usr/local/nagion/etc/nrpe.cfg -n –d
ps -ef | grep nrpe
srikanth.kallu
uvdev:/tmp/aix-nrpe-agent# ps -ef | grep nrpe
root 11862458 10092704 0 14:32:50 pts/26 0:00 grep nrpe
This thread is being worked in email support ticket but was caused by openssl not being installed.
