How to build RPM out of Nagios Check files
linuxfreaker
Post by linuxfreaker »
I have 3 nagios check files namely - check_idms.py, check_tomcat and check_soap.
I built cdnagioscheck-1.0.tar.gz.I copied that tar file udnder /home/rpmbuild/rpm/SOURCES.I took an old SPEC file format from /home/rpmbuild/rpm/SPECS.Now I need to create SPEC file out of those 3 spec file so that it can be integrated/installed during nagios server setup.
Here is the SPEC file I tried to create:
Summary: cdnagios check
Version: 1.0
Release: 0
License: BSD
Group: Applications/Internet
Source: cdnagioscheck-%{version}.tar.gz
BuildRoot: %{_tmppath}/%{name}-%{version}-%{release}-root-%(%{__id_u} -n)
BuildArch: noarch
Requires: nagios
# The above perl libraries are for postgresql monitoring.
%description
Provides aclient specific checks for the mdnagios - check_tomcat, _check_idms,check_soap.
%prep
%setup -q
%install
mkdir -p $RPM_BUILD_ROOT/usr/lib64/nagios/plugins/
%clean
rm -rf $RPM_BUILD_ROOT
%post
/etc/init.d/postgresql reload
/etc/init.d/tomcat6 restart
%postun
/etc/init.d/tomcat6 stop
echo "Removing deployed cNIS files from Tomcat."
rm -Rf /var/lib/tomcat6/webapps/cma/
rm -Rf /var/lib/tomcat6/webapps/abs/
/etc/init.d/tomcat6 start
echo "Removing PostgreSQL user and database."
if ! ps ax | grep -v grep | grep postgres > /dev/null
then
    /sbin/service postgresql start
fi
su - postgres -c "psql -c \"drop database if exists cnis;\"" > /dev/null 2>&1
su - postgres -c "psql -c \"drop user cnis;\"" > /dev/null 2>&1
sed -i '/.*cnis.*/d' /var/lib/pgsql/data/pg_hba.conf
%files
%defattr(-,mdnagios,-)
/usr/lib64/nagios/plugins/check_tomcat
/usr/lib64/nagios/plugins/check_idms
/usr/lib64/nagios/plugins/check_soap
%changelog
I am not sure if that is the correct format (esp. install and files section).
But when I am trying to build RPM through the following command:
[rpmbuild@gnmonitoring SPECS]$ rpmbuild -bb mdnagioscheck.spec
Executing(%install): /bin/sh -e /var/tmp/rpm-tmp.ADxnow
+ umask 022
+ cd /home/rpmbuild/rpm/BUILD
+ '[' /home/rpmbuild/rpm/BUILDROOT/mdnagioscheck-1.0-0.x86_64 '!=' / ']'
+ rm -rf /home/rpmbuild/rpm/BUILDROOT/mdnagioscheck-1.0-0.x86_64
++ dirname /home/rpmbuild/rpm/BUILDROOT/mdnagioscheck-1.0-0.x86_64
+ mkdir -p /home/rpmbuild/rpm/BUILDROOT
+ mkdir /home/rpmbuild/rpm/BUILDROOT/mdnagioscheck-1.0-0.x86_64
+ LANG=C
+ export LANG
+ unset DISPLAY
+ mkdir temp
mkdir: cannot create directory `temp': File exists
error: Bad exit status from /var/tmp/rpm-tmp.ADxnow (%install)
RPM build errors:
Any idea how shall I fix this issue?
agriffin
Re: How to build RPM out of Nagios Check files
Post by agriffin »
This question should probably be asked in a more relevant place. Knowledge about Nagios doesn't really enable anyone to answer it.
