NRDS WIN NOT WORKING
shirishlnx
Post by shirishlnx »
With NRDS Config Manager, have created a config for windows 32bit and downloaded the installation utility .
After installation have placed all info like NRDP URL, TOKEN, Config Manager, Host Name , Interval .
But can see dir, C:\Program Files\Nagios\NRDS_Win/plugin is blank and even scheduler was not set automatically and nodes not discovered in Unconfigured Objects tab also the in config.ini [services] fields are blank .
Have verified xineted configuration, firewall and "Inbound Transfers" all are okay .
Please clear me below doubt,
1. Do we require to copy all plugin manually from Nagios server .
2. Do we need manually create scheduler
Shirish
Re: NRDS WIN NOT WORKING
1.) No, NRDS will do this for you
2.) The installer should do this.
Be sure you fill in ALL of the fields are filled in when you run the installer, specifically the hostname (this is how you want the server named in Nagios XI)
shirishlnx
Yes .. it working now .. but have found it's not creating scheduler automatic .
Also I would be helpfull if you can help me how to clear all "Unconfigured Objects" request .
To clearall unconfigured objects it is easiest to run the following from the command prompt
rm -f /usr/local/nagiosxi/var/corelog.newobjects
shirishlnx
Thanks It's Done .. now am getting problem when using same plugin to monitor different paramiters .
And not getting updated request in undiscovered object .
---------------------------------NRDS_Debug.log
command[__HOST__] = $PLUGIN_DIR$\check_winping.exe -H 127.0.0.1 --warning 200,40% --critical 400.0,80%
command[nrpe_winprocess] = $PLUGIN_DIR$\check_winprocess.exe --warning 40 --critical 50
command[nrpe_process] = $PLUGIN_DIR$\cpuload_nrpe_nt.exe 70 90
command[nrpe_diskspace] = $PLUGIN_DIR$\diskspace_nrpe_nt.exe c: 77 90
command[nrpe_eventlog] = $PLUGIN_DIR$\eventlog_nrpe_nt.exe -m 7200
command[nrpe_memload] = $PLUGIN_DIR$\memload_nrpe_nt.exe 70 90
command[nrpe_service] = $PLUGIN_DIR$\service_nrpe_nt.exe "DNS Client"
command[nrpe_mssql] = $PLUGIN_DIR$\check_mssqls_nt.exe /H:127.0.0.1 /D:FusionServer /U:sa -P:m0rg01 /CHK_QUERY:"select * from HIPAA_Event"
command[mssql_DB_connect] = $PLUGIN_DIR$\check_mssqls_nt.exe /H:127.0.0.1 /D:FusionServer /U:sa -P:m0rg01 /CHK_CONNECT
</config>
</result>
9/13/2012 11:49:55 PM Config update availability : False
yancy
Post by yancy »
shirishlnx,
If the hostname defined in host.ini matches the hostname being monitored, the checks not be in undiscovered objects.
Regards,
-Yancy
