Upgrade to 2011r3.3 and Ajaxterm pkg not Found
pnnagios
Post by pnnagios »
I attempted to upgrade our Nagios server from 2011R3.2 to 2011R3.3, and the upgrade failed with yum unable to find the Ajaxterm package.
Running configuration check...done.
Stopping nagios: .done.
Starting nagios: done.
Installing Ajaxterm...
Loaded plugins: fastestmirror
Loading mirror speeds from cached hostfile
 * base: mirror.cisp.com
 * epel: fedora.westmancom.com
 * extras: mirrors.einstein.yu.edu
 * rpmforge: mirror.rit.edu
 * updates: mirror.linux.duke.edu
Setting up Install Process
Package 1:mod_ssl-2.2.15-15.el6.centos.1.x86_64 already installed and latest version
Nothing to do
Setting up Local Package Process
Cannot open: /tmp/nagiosxi/packages/Ajaxterm-0.10-8.el5.noarch.rpm. Skipping.
Nothing to do
Ajaxterm install failed.
./install: line 22: return: can only `return' from a function or sourced script
We are using CentOS 6.2 64-bit, and the EPEL repository is added.
[root@nagiosdev1 etc]# yum repolist
repo id        repo name        status
base        CentOS-6 - Base        6,346
cr        CentOS-6 - CR        0
epel        Extra Packages for Enterprise Linux 6 - x86_64        7,765
extras        CentOS-6 - Extras        4
rpmforge        RHEL 6 - RPMforge.net - dag        4,433
updates        CentOS-6 - Updates        542
repolist: 19,090
If we try to install Ajaxterm with yum, it also, fails with a package not found error. I could be wrong, but it seems that Ajaxterm is not available for CentOS 6.2 64-bit? Can anyone else confirm this, or offer any insight?
Thank you,
Paul
Re: Upgrade to 2011r3.3 and Ajaxterm pkg not Found
Post by slansing »
Ajaxterm is a feature that will be available in XI 2012, some of these features are being added in XI 2011 3.3 as it is the last major release before 2012. To skip this installation bit please run the following from the install directory:
cat /dev/null > subcomponents/ajaxterm/install
pnnagios
Post by pnnagios »
I removed that step from the installation as suggested, and the upgrade completed successfully now.
Thank you,
Paul
