Performance Graphs Not Updating
transom324
Post by transom324 »
The performance graphs on my system stopped updating on 09/07/2012. We did get a key to extend our software trial last week also. Would that effect the graphs?
Tom
Tom
mguthrie
Re: Performance Graphs Not Updating
Post by mguthrie »
No, it shouldn't, but try the following solution and see if it applies to your situation.
http://support.nagios.com/wiki/index.ph ... ve_No_Data
Also, make sure the performance graphing service is running ok.
service npcd restart
transom324
mguthrie,
Thanks for getting back to me. I have tried restarting the npcd service several times and I ran the script to reset the perms. Here's the output from the command that you pointed to me to:
[root@nagiosxi ~]# cd /usr/local/nagios/var/spool/xidpe
[root@nagiosxi xidpe]# ls -f | wc -l
2
Tom
mguthrie
Post by mguthrie »
Is your CPU load over 10.0 by chance?
Do you get and recent error messages when tailing the following log files?
tail -f /usr/local/nagios/var/perfdata.log
tail -f /usr/local/nagios/var/npcd.log
transom324
tail -f /usr/local/nagios/var/npcd.log is constantly updating. Here's the output from the tail -f /usr/local/nagios/var/perfdata.log:
[root@nagiosxi ~]# tail -f /usr/local/nagios/var/perfdata.log
2012-09-03 12:01:42 [24740] [0] *** TIMEOUT: Please check your npcd.cfg
2012-09-03 12:01:42 [24740] [0] *** TIMEOUT: /usr/local/nagios/var/spool/perfdata//1346673676.perfdata.service-PID-24740 deleted
2012-09-03 12:01:42 [24740] [0] *** Timeout while processing Host: "pesxi03" Service: "Memory_for_VMHost"
2012-09-03 12:01:42 [24740] [0] *** process_perfdata.pl terminated on signal ALRM
2012-09-05 00:04:06 [29550] [0] *** TIMEOUT: Timeout after 5 secs. ***
2012-09-05 00:04:06 [29550] [0] *** TIMEOUT: Deleting current file to avoid NPCD loops
2012-09-05 00:04:06 [29550] [0] *** TIMEOUT: Please check your npcd.cfg
2012-09-05 00:04:06 [29550] [0] *** TIMEOUT: /usr/local/nagios/var/spool/perfdata//1346803426.perfdata.service-PID-29550 deleted
2012-09-05 00:04:06 [29550] [0] *** Timeout while processing Host: "centcshctx04" Service: "CPU_Usage_for_VMHost"
2012-09-05 00:04:06 [29550] [0] *** process_perfdata.pl terminated on signal ALRM
Tom
transom324
mguthrie,
The performance graphs appear to be slowly populating now. The system load is at 0.67 but the I/O wait time is at 63.30.
Tom
Did the performance graphs update? Is the issue resolved?
transom324
Well... the performance graphs are up to date now. Thanks. But, now the server statistics are not updating. Should I start another post for that issue?
Tom
Lets run to following to make sure that cron is listed
ps -ef |grep sysstat.php
transom324
Here's the output:
[root@nagiosxi ~]# ps -ef |grep sysstat.php
root 22513 22246 1 13:04 pts/0 00:00:00 grep sysstat.php
[root@nagiosxi ~]#
Tom
