Hi Everyone,
Good morning, from last 4 days my nagios logs are not populating but all checks are going smooth with out any issues.
Which entry I missed, I am not sure. You help if very useful to me. Please let me what to change and where to change.
Thank you in advance.
Bhargava.
Nagios logs are not populating
Re: Nagios logs are not populating
I'm not sure I 100% understand what you mean... As in nagios/var/nagios.log is empty? Are you able to provide some screenshots and/or specifics?
Hi JSMurthy,
Thank you for reply. Yes the /var/logs/nagios/nagios.log is not populating with what nagios is doing. Like sending for hostchecks and all. I updated around 800 checks and only check updated in log is about the present server status.
fyi:
[1348143483] EXTERNAL COMMAND: PROCESS_SERVICE_CHECK_RESULT;nmdcentral02;RootDiskCheck;0;DISK OK - free space: / 2692 MB (31% inode=89%);| /=5917MB;8163;8617;0;9071
[1348143484] PASSIVE SERVICE CHECK: nmdcentral02;RootDiskCheck;0;DISK OK - free space: / 2692 MB (31% inode=89%):
[1348143603] EXTERNAL COMMAND: PROCESS_SERVICE_CHECK_RESULT;nmdcentral02;RootDiskCheck;0;DISK OK - free space: / 2691 MB (31% inode=89%);| /=5918MB;8163;8617;0;9071
[1348143604] PASSIVE SERVICE CHECK: nmdcentral02;RootDiskCheck;0;DISK OK - free space: / 2691 MB (31% inode=89%):
[1348143723] EXTERNAL COMMAND: PROCESS_SERVICE_CHECK_RESULT;nmdcentral02;RootDiskCheck;0;DISK OK - free space: / 2691 MB (31% inode=89%);| /=5919MB;8163;8617;0;9071
[1348143724] PASSIVE SERVICE CHECK: nmdcentral02;RootDiskCheck;0;DISK OK - free space: / 2691 MB (31% inode=89%):
[1348143843] EXTERNAL COMMAND: PROCESS_SERVICE_CHECK_RESULT;nmdcentral02;RootDiskCheck;0;DISK OK - free space: / 2690 MB (31% inode=89%);| /=5920MB;8163;8617;0;9071
[1348143844] PASSIVE SERVICE CHECK: nmdcentral02;RootDiskCheck;0;DISK OK - free space: / 2690 MB (31% inode=89%):
[1348143963] EXTERNAL COMMAND: PROCESS_SERVICE_CHECK_RESULT;nmdcentral02;RootDiskCheck;0;DISK OK - free space: / 2689 MB (31% inode=89%);| /=5920MB;8163;8617;0;9071
[1348143964] PASSIVE SERVICE CHECK: nmdcentral02;RootDiskCheck;0;DISK OK - free space: / 2689 MB (31% inode=89%):
[1348144083] EXTERNAL COMMAND: PROCESS_SERVICE_CHECK_RESULT;nmdcentral02;RootDiskCheck;0;DISK OK - free space: / 2689 MB (31% inode=89%);| /=5921MB;8163;8617;0;9071
[1348144084] PASSIVE SERVICE CHECK: nmdcentral02;RootDiskCheck;0;DISK OK - free space: / 2689 MB (31% inode=89%):
[1348144203] EXTERNAL COMMAND: PROCESS_SERVICE_CHECK_RESULT;nmdcentral02;RootDiskCheck;0;DISK OK - free space: / 2688 MB (31% inode=89%);| /=5922MB;8163;8617;0;9071
[1348144204] PASSIVE SERVICE CHECK: nmdcentral02;RootDiskCheck;0;DISK OK - free space: / 2688 MB (31% inode=89%):
[1348144323] EXTERNAL COMMAND: PROCESS_SERVICE_CHECK_RESULT;nmdcentral02;RootDiskCheck;0;DISK OK - free space: / 2687 MB (31% inode=89%);| /=5923MB;8163;8617;0;9071
[1348144324] PASSIVE SERVICE CHECK: nmdcentral02;RootDiskCheck;0;DISK OK - free space: / 2687 MB (31% inode=89%):
[1348144443] EXTERNAL COMMAND: PROCESS_SERVICE_CHECK_RESULT;nmdcentral02;RootDiskCheck;0;DISK OK - free space: / 2686 MB (31% inode=89%);| /=5923MB;8163;8617;0;9071
[1348144444] PASSIVE SERVICE CHECK: nmdcentral02;RootDiskCheck;0;DISK OK - free space: / 2686 MB (31% inode=89%):
[1348144563] EXTERNAL COMMAND: PROCESS_SERVICE_CHECK_RESULT;nmdcentral02;RootDiskCheck;0;DISK OK - free space: / 2686 MB (31% inode=89%);| /=5924MB;8163;8617;0;9071
[1348144564] PASSIVE SERVICE CHECK: nmdcentral02;RootDiskCheck;0;DISK OK - free space: / 2686 MB (31% inode=89%):
[1348144683] EXTERNAL COMMAND: PROCESS_SERVICE_CHECK_RESULT;nmdcentral02;RootDiskCheck;0;DISK OK - free space: / 2685 MB (31% inode=89%);| /=5925MB;8163;8617;0;9071
[1348144684] PASSIVE SERVICE CHECK: nmdcentral02;RootDiskCheck;0;DISK OK - free space: / 2685 MB (31% inode=89%):
[1348144803] EXTERNAL COMMAND: PROCESS_SERVICE_CHECK_RESULT;nmdcentral02;RootDiskCheck;0;DISK OK - free space: / 2684 MB (31% inode=89%);| /=5925MB;8163;8617;0;9071
[1348144804] PASSIVE SERVICE CHECK: nmdcentral02;RootDiskCheck;0;DISK OK - free space: / 2684 MB (31% inode=89%):
[1348144923] EXTERNAL COMMAND: PROCESS_SERVICE_CHECK_RESULT;nmdcentral02;RootDiskCheck;0;DISK OK - free space: / 2683 MB (31% inode=89%);| /=5926MB;8163;8617;0;9071
[1348144924] PASSIVE SERVICE CHECK: nmdcentral02;RootDiskCheck;0;DISK OK - free space: / 2683 MB (31% inode=89%):
[1348145034] SERVICE ALERT: sys2;FilemoverProgsStatus;CRITICAL;SOFT;1;CRITICAL: cmos.to.compass.prod.filemover not running on sys2
[1348145043] EXTERNAL COMMAND: PROCESS_SERVICE_CHECK_RESULT;nmdcentral02;RootDiskCheck;0;DISK OK - free space: / 2683 MB (31% inode=89%);| /=5927MB;8163;8617;0;9071
[1348145044] PASSIVE SERVICE CHECK: nmdcentral02;RootDiskCheck;0;DISK OK - free space: / 2683 MB (31% inode=89%):
[1348145154] SERVICE ALERT: sys2;FilemoverProgsStatus;CRITICAL;SOFT;2;CRITICAL: cmos.to.compass.prod.filemover not running on sys2
[1348145163] EXTERNAL COMMAND: PROCESS_SERVICE_CHECK_RESULT;nmdcentral02;RootDiskCheck;0;DISK OK - free space: / 2682 MB (31% inode=89%);| /=5928MB;8163;8617;0;9071
fyi:
Nagios doesn't log every check it runs, that would be a HUGE performance hit and an enormous amount of information. Nagios will log state changes, external commands, passive checks, etc, but the different logging settings can be configured in the main nagios.cfg file.
