Selenium packages not available from nagios repository
Can check with this packages, one of the requirements to download is not available from repositories, kindly advise.
Re: Selenium packages not available from nagios repository
Try this link:
http://assets.nagios.com/downloads/nagi ... .06.tar.gz
There were some bad links in the documentation. They should be fixed now. Let us know if you have any more issues.
Hi
Thank you, manage to download and compile the packages successfully, but encounter error when trying to rung the script.
Please help
[root@150 selenium]# telnet localhost 4444
Trying 127.0.0.1...
Connected to localhost.localdomain (127.0.0.1).
Escape character is '^]'.
[root@150 selenium]# perl LIFEHUBPERL
Error requesting http://localhost:4444/selenium-server/driver/:
Failed to start new browser session: Error while launching browser
# Looks like your test died before it could output anything.
[root@150 selenium]# java -jar selenium-server-standalone-2.25.0.jar
Sep 19, 2012 8:41:20 AM org.openqa.grid.selenium.GridLauncher main
INFO: Launching a standalone server
08:41:41.543 INFO - Java: Sun Microsystems Inc. 20.0-b11
08:41:41.551 INFO - OS: Linux 2.6.18-194.el5 i386
08:41:41.592 INFO - v2.25.0, with Core v2.25.0. Built from revision 17482
08:41:42.039 INFO - RemoteWebDriver instances should connect to: http://127.0.0.1:4444/wd/hub
08:41:42.042 INFO - Version Jetty/5.1.x
08:41:42.045 INFO - Started HttpContext[/selenium-server/driver,/selenium-server/driver]
08:41:42.047 INFO - Started HttpContext[/selenium-server,/selenium-server]
08:41:42.047 INFO - Started HttpContext[/,/]
08:41:42.126 INFO - Started org.openqa.jetty.jetty.servlet.ServletHandler@1549f94
08:41:42.126 INFO - Started HttpContext[/wd,/wd]
08:41:42.171 INFO - Started SocketListener on 0.0.0.0:4444
08:41:42.171 INFO - Started org.openqa.jetty.jetty.Server@d6c16c
08:42:09.624 INFO - Checking Resource aliases
08:42:09.637 INFO - Command request: getNewBrowserSession[*chrome, https://elogin.lifeisgreat.com.sg/] on session null
08:42:09.644 INFO - creating new remote session
08:42:09.829 INFO - Allocated session 16b7316d154b44e2bb76301cf7bce5dc for https://elogin.lifeisgreat.com.sg/, launching...
jar:file:/usr/local/selenium/selenium-server-standalone-2.25.0.jar!/customProfileDirCUSTFFCHROME
08:42:10.002 INFO - Preparing Firefox profile...
08:42:30.142 ERROR - Failed to start new browser session, shutdown browser and clear all session data
java.lang.RuntimeException: Timed out waiting for profile to be created!
at org.openqa.selenium.server.browserlaunchers.FirefoxChromeLauncher.waitForFullProfileToBeCreated(FirefoxChromeLauncher.java:308)
at org.openqa.selenium.server.browserlaunchers.FirefoxChromeLauncher.populateCustomProfileDirectory(FirefoxChromeLauncher.java:120)
at org.openqa.selenium.server.browserlaunchers.FirefoxChromeLauncher.launch(FirefoxChromeLauncher.java:90)
at org.openqa.selenium.server.browserlaunchers.FirefoxChromeLauncher.launchRemoteSession(FirefoxChromeLauncher.java:347)
at org.openqa.selenium.server.BrowserSessionFactory.createNewRemoteSession(BrowserSessionFactory.java:399)
at org.openqa.selenium.server.BrowserSessionFactory.getNewBrowserSession(BrowserSessionFactory.java:143)
at org.openqa.selenium.server.BrowserSessionFactory.getNewBrowserSession(BrowserSessionFactory.java:104)
at org.openqa.selenium.server.SeleniumDriverResourceHandler.getNewBrowserSession(SeleniumDriverResourceHandler.java:811)
at org.openqa.selenium.server.SeleniumDriverResourceHandler.doCommand(SeleniumDriverResourceHandler.java:437)
at org.openqa.selenium.server.SeleniumDriverResourceHandler.handleCommandRequest(SeleniumDriverResourceHandler.java:407)
at org.openqa.selenium.server.SeleniumDriverResourceHandler.handle(SeleniumDriverResourceHandler.java:151)
at org.openqa.jetty.http.HttpContext.handle(HttpContext.java:1526)
at org.openqa.jetty.http.HttpContext.handle(HttpContext.java:1479)
at org.openqa.jetty.http.HttpServer.service(HttpServer.java:914)
at org.openqa.jetty.http.HttpConnection.service(HttpConnection.java:820)
at org.openqa.jetty.http.HttpConnection.handleNext(HttpConnection.java:986)
at org.openqa.jetty.http.HttpConnection.handle(HttpConnection.java:837)
at org.openqa.jetty.http.SocketListener.handleConnection(SocketListener.java:243)
at org.openqa.jetty.util.ThreadedServer.handle(ThreadedServer.java:357)
at org.openqa.jetty.util.ThreadPool$PoolThread.run(ThreadPool.java:534)
08:42:30.159 INFO - Got result: Failed to start new browser session: Error while launching browser on session null
Please help
Trying 127.0.0.1...
This looks like it couldn't open a firefox session. I'm going to have the person who wrote our Selenium docs take a look at this..
Have you attempted to use:
Instead of the Chrome browser for the script's launch options. Chrome "as stated in the documentation" is a special version of Firefox you may not have? When creating this documentation only Firefox standard was used for testing as it is the most readily available browser cross platform.
Can you post your custom selenium script here? Blocking out sensitive information.
*firefoxCan you post your custom selenium script here? Blocking out sensitive information.
i registered from a customer support index, but i was not able to post a topic? i cant find the new topic button to post, please assist
If you have purchased XI please contact [email protected] with your customer ID to get your forum username added to the customer list in the forum
Thank you, will email the customer id to [email protected], will you be able to help me on this error, recorded and playback from selenium ide no error, however when i try the commandscottwilkerson wrote:If you have purchased XI please contact [email protected] with your customer ID to get your forum username added to the customer list in the forum
[root@nagmine selenium]# perl lifehub2
ok 1 - open, /sso/jsp/login.jsp?site2pstoretoken=v1.2~D0DE34AC~0DAD980CAA8D3F8823AA41E9297A2548D41C0AFF65F24DA4BC66B24F55F906294301056F418AFB275414263951B218A0CD800C6B41CCB2962895651425A028BBEC74AA8C809D2B89AFAE24AFCD2E2C859EDEFABD4CE61EEEE19A9A5E1FD82B6299E62BB205DDE24312658E0AD8A49FF44F1BCBD6DB47D574780691045CC60C93F227F06F489C6CF14447DF564FC2C06DC26673D08231E9C30F5B1D9CBCAE8D26F2F0C63CE52C46B078D9083ED4A01E4F97623F03038738FEBC16A1AFF6D09225B24169F89D72D9BA&p_error_code=&p_submit_url=https%3A%2F%2Furl.com%2Fsso%2Fauth&p_cancel_url=http%3A%2F%2Furl.com&ssousername=
ok 2 - type, name=ssousername, userid
ok 3 - type, name=password, password
ok 4 - click, id=btn_submit
ok 5 - wait_for_page_to_load, 30000
[b]# Error requesting http://localhost:4444/selenium-server/driver/:
# ERROR: Element id=OTP not found
not ok 6 - click, id=OTP[/b]
[b]# Failed test 'click, id=OTP'
# at lifehub2 line 18.[/b]
[root@nagmine selenium]# cat lifehub2
use strict;
use warnings;
use Time::HiRes qw(sleep);
use Test::WWW::Selenium;
use Test::More "no_plan";
use Test::Exception;
my $sel = Test::WWW::Selenium->new( host => "localhost",
port => 4444,
browser => "*firefox",
browser_url => "https://url.com/" );
$sel->open_ok("/sso/jsp/login.jsp?site2pstoretoken=v1.2~D0DE34AC~0DAD980CAA8D3F8823AA41E9297A2548D41C0AFF65F24DA4BC66B24F55F906294301056F418AFB275414263951B218A0CD800C6B41CCB2962895651425A028BBEC74AA8C809D2B89AFAE24AFCD2E2C859EDEFABD4CE61EEEE19A9A5E1FD82B6299E62BB205DDE24312658E0AD8A49FF44F1BCBD6DB47D574780691045CC60C93F227F06F489C6CF14447DF564FC2C06DC26673D08231E9C30F5B1D9CBCAE8D26F2F0C63CE52C46B078D9083ED4A01E4F97623F03038738FEBC16A1AFF6D09225B24169F89D72D9BA&p_error_code=&p_submit_url=https%3A%2F%2Furl.com%2Fsso%2Fauth&p_cancel_url=http%3A%2F%2Furl.com&ssousername=");
$sel->type_ok("name=ssousername", "userid");
$sel->type_ok("name=password", "password");
$sel->click_ok("id=btn_submit");
$sel->wait_for_page_to_load_ok("30000");
$sel->click_ok("id=OTP");
$sel->type_ok("id=OTIP", "123456");
WAIT: {
for (1..60) {
if (eval { $sel->is_element_present("link=Home") }) { pass; last WAIT }
sleep(1);
fail("timeout");
selenium ide source:
<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
<html xmlns="http://www.w3.org/1999/xhtml" xml:lang="en" lang="en">
<head profile="http://selenium-ide.openqa.org/profiles/test-case">
<meta http-equiv="Content-Type" content="text/html; charset=UTF-8" />
<link rel="selenium.base" href="https://url.com/" />
<title>New Test</title>
</head>
<body>
<table cellpadding="1" cellspacing="1" border="1">
<thead>
<tr><td rowspan="1" colspan="3">New Test</td></tr>
</thead><tbody>
<tr>
<td>open</td>
<td>/sso/jsp/login.jsp?site2pstoretoken=v1.2~D0DE34AC~0DAD980CAA8D3F8823AA41E9297A2548D41C0AFF65F24DA4BC66B24F55F906294301056F418AFB275414263951B218A0CD800C6B41CCB2962895651425A028BBEC74AA8C809D2B89AFAE24AFCD2E2C859EDEFABD4CE61EEEE19A9A5E1FD82B6299E62BB205DDE24312658E0AD8A49FF44F1BCBD6DB47D574780691045CC60C93F227F06F489C6CF14447DF564FC2C06DC26673D08231E9C30F5B1D9CBCAE8D26F2F0C63CE52C46B078D9083ED4A01E4F97623F03038738FEBC16A1AFF6D09225B24169F89D72D9BA&p_error_code=&p_submit_url=https%3A%2F%2Furl.com%2Fsso%2Fauth&p_cancel_url=http%3A%2F%2Furl.com&ssousername=</td>
<td></td>
</tr>
<tr>
<td>type</td>
<td>name=ssousername</td>
<td>userid</td>
</tr>
<tr>
<td>type</td>
<td>name=password</td>
<td>password</td>
</tr>
<tr>
<td>clickAndWait</td>
<td>id=btn_submit</td>
<td></td>
</tr>
<tr>
<td>id=OTP</td>
<td></td>
</tr>
<tr>
<td>type</td>
<td>id=OTIP</td>
<td>123456</td>
</tr>
<tr>
<td>id=OTP</td>
<td></td>
</tr>
<tr>
<td>waitForElementPresent</td>
<td>link=Home</td>
<td></td>
</tr>
</tbody></table>
</body>
</html>
selenium ide logs;
[info] Executing: |open | /sso/jsp/login.jsp?site2pstoretoken=v1.2~D0DE34AC~0DAD980CAA8D3F8823AA41E9297A2548D41C0AFF65F24DA4BC66B24F55F906294301056F418AFB275414263951B218A0CD800C6B41CCB2962895651425A028BBEC74AA8C809D2B89AFAE24AFCD2E2C859EDEFABD4CE61EEEE19A9A5E1FD82B6299E62BB205DDE24312658E0AD8A49FF44F1BCBD6DB47D574780691045CC60C93F227F06F489C6CF14447DF564FC2C06DC26673D08231E9C30F5B1D9CBCAE8D26F2F0C63CE52C46B078D9083ED4A01E4F97623F03038738FEBC16A1AFF6Durl.com&ssousername= | |
[info] Executing: |type | name=ssousername | <userid> |
[info] Executing: |type | name=password | <password> |
[info] Executing: |clickAndWait | id=btn_submit | |
[info] Executing: |clickAndWait | id=OTP | |
[info] Executing: |type | id=OTIP | 123456 |
[info] Executing: |waitForElementPresent | link=Home | |
Last edited by scottwilkerson on Fri Mar 29, 2013 8:52 am, edited 3 times in total.
Reason: wrapped in code
Have you attempted the addition of "Pause on Fail" to the IDE? Without it, the IDE may spin it's wheels until a timeout value is met.. please have a look at this firefox addon:
https://addons.mozilla.org/en-us/firefo ... enium-ide/
This seems to be more an issue on the IDE's end and not your test case script. I am curious to see how this addon will play out once you add it.
Hi
Same thing, after installing the addons power debugger, no problem on ide recorder but when running this command,
how will i resolve this is urgent on our production applications monitoring.
[root@nagmine selenium]# perl <filename>
ok 1 - open, /sso/jsp/login.jsp?site2pstoretoken=v1.2~D0DE34AC~B94869D5078F6E4E8DB56999AC4315594A0CA947E3523D6E8202EA86395F8856B9803672829ABDCD003AD0DFDA86CEE9367EDBEAA14616DF3AC7AFFA868192B5D699327998FD5A002E6E2BF3DD651A5AA7E500AA4E1D83F3800AD6A8269E0A4389FB4A1B0E1D1A9D99D3784C5B75D632101361ACAF2C6276881EB5DD692BDC100B04E88BFCA813642D888D0A28289DD8D12F1B2A6FC2EFBC77238CA89DF8E41F6531529D2873F69A73FA9067A9A66259E7158F42344E7DC27AB5D3DCCBBD0AB731E963DD3A47EECA&p_error_code=&p_submit_url=https%3A%2F%2Frul.com%2Fsso%2Fauth&p_cancel_url=http%3A%2F%2Furl.com&ssousername=
# at lifehub5 line 18.
# Timed out after 30000ms
not ok 7 - wait_for_page_to_load, 30000
# Failed test 'wait_for_page_to_load, 30000'
# at lifehub5 line 19.
# ERROR: Element id=OTIP not found
not ok 8 - type, id=OTIP, 123456
# Failed test 'type, id=OTIP, 123456'
# at lifehub5 line 20.
not ok 9 - click, id=OTP
# at lifehub5 line 21.
not ok 10 - wait_for_page_to_load, 30000
# at lifehub5 line 22.
1..10
# Looks like you failed 5 tests of 10.
1..10
