NSClient++ agent installation on Windows Server
MSPk
Post by MSPk »
HI,
Can we install NSClient++ agent on the windows server which is already being monitored by BMC tool and has a BMC agent installed on it? As we need BMC to monitor the server till nagios goes live. Are there any pre-requisites we need to take care before we do this?
BanditBBS
Re: NSClient++ agent installation on Windows Server
Post by BanditBBS »
As long as they don't listen on the same ports there should be no issue in using both at same time.
NSC installs easily and no pre-reqs that I can think of.
2 of XI5.6.14 Prod/DR/DEV - Nagios LogServer 2 Nodes
See my projects on the Exchange at BanditBBS - Also check out my Nagios stuff on my personal page at Bandit's Home and at github
BanditBBS is correct. Nothing else I can think of that would cause problems.
