Nagios XI on CentOS 5 installation issue
arendu
Post by arendu »
I have installed nagios on CentOS 5 32 bit.
This server is on local LAN and its uptodate.
*******************Error**********************
http: //mirror.unl.edu/centos/5.6/updates/i386/repodata/filelists.sqlite.bz2*: [Errno 14] HTTP Error 404: Not Found
Trying other mirror.
http: //centos-distro.cavecreek.net/centos/5.6/updates/i386/repodata/filelists.sqlite.bz2*: [Errno 14] HTTP Error 404: Not Found
http: //centosf3.centos.org/centos/5.6/updates/i386/repodata/filelists.sqlite.bz2*: [Errno 14] HTTP Error 404: Not Found
http: //centosq4.centos.org/centos/5.6/updates/i386/repodata/filelists.sqlite.bz2*: [Errno 14] HTTP Error 404: Not Found
http: //centos.mbni.med.umich.edu/mirror/5.6/updates/i386/repodata/filelists.sqlite.bz2*: [Errno 14] HTTP Error 404: Not Found
http: //centoso4.centos.org/centos/5.6/updates/i386/repodata/filelists.sqlite.bz2: [Errno 14] HTTP Error 404: Not Found
http://mirrors.gigenet.com/centos/5.6/u ... sqlite.bz2: [Errno 14] HTTP Error 404: Not Found
http: //centosk3.centos.org/centos/5.6/updates/i386/repodata/filelists.sqlite.bz2: [Errno 14] HTTP Error 404: Not Found
http: //centosq2.centos.org/centos/5.6/updates/i386/repodata/filelists.sqlite.bz2: [Errno 14] HTTP Error 404: Not Found
http: //mirror.teklinks.com/centos/5.6/updates/i386/repodata/filelists.sqlite.bz2: [Errno -1] Metadata file does not match checksum
Error: failure: repodata/filelists.sqlite.bz2 from updates: [Errno 256] No more mirrors to try.
You could try using --skip-broken to work around the problem
You could try running: package-cleanup --problems
package-cleanup --dupes
rpm -Va --nofiles --nodigest
The program package-cleanup is found in the yum-utils package.
RESULT=1
INSTALLATION ERROR!
in your communications with Nagios XI technical support.
The script that failed was: './1-prereqs'
---Arendu :)
Re: Nagios XI on CentOS 5 installation issue
Is this machine behind a proxy? It appears that it cannot reach any of the yum repositories...
