Hi i have installed nagios and nagvis , but when i click on automap it shows only localhost.
I understand that there is a need to set parent child relation for the hosts, but i do not know how to go about. Any help would be appreciated. Thanks !
Nagvis Automap Only shows localhost
Re: Nagvis Automap Only shows localhost
If you go to a
Host Detail Page -> Configure -> Re-configure this host -> Parents tab
you can select the hosts parent
Another way to do this is to go to
Configure -> CCM -> Hosts -> Modify
Select Parent by clicking the notepad next to parents field
Thanks i managed to solve it. Just by specifying the parent will solve itscottwilkerson wrote:If you go to a
