Errors On Monitoring After Installation
ScottP
Post by ScottP »
I am very new to Nagios Core, we have viewed the demo and are very happy with what the system provides, but I am stumped on setting it up now. I have got it installed without error but now when I look at my localhost server it says it is down and gives me the following error:
 (Return code of 127 is out of bounds - plugin may be missing)
Thanks in advanced for the help.
Scott
mguthrie
Re: Errors On Monitoring After Installation
Post by mguthrie »
Can you post the command definition that us being referenced by this service?
This error usually occurs if a plugin is not executable, or not executable by the Nagios user, or if the plugin itself is not the correct directory location.
