Services Disappered
John12
Services Disappered
Post by John12 »
hi,
VMware Virtual Machine (64-bit) 2011R3.3 on centos 5.7 64bit running VMWare workstation.
error msg1: SQL: SQL Error [ndoutils] : Incorrect file format 'nagios_servicestatus'
error msg2: SQL: SQL Error [ndoutils] : Table './nagios/nagios_servicestatus'
My core config manager has the serivce details but home service panel doesnt shows up.
I am getting error as
I tried
/usr/local/nagiosxi/scripts/repairmysql.sh nagios
(and)
/usr/local/nagiosxi/scripts/repairmysql.sh nagiosql
, but that didnt solved the services to appear.
I navigate on the forum and found similar post with method to try..
service mysqld stop
cd /var/lib/mysql/nagios
myisamchk -r -f nagios_<corrupted_table>
service mysqld start
rm -f /usr/local/nagiosxi/var/dbmaint.lock
/usr/local/nagiosxi/cron/dbmaint.php
I would like to know what is the exact syntax i follow..
myisamchk -r -f nagios_<corrupted_table> .. i see servicestatus.frm, servicestatus.MYI, servicestatus.MYD
I tried
mysqlcheck --auto-repair -A -pnagiosxi
with my custom password. and got the following errors as shown..
Pls let me know what else i try to bring the service details.
awaiting ..
Thanks.
John12
Re: Services Disappered
Post by John12 »
Some with any workaround.. i would be greatly thankful.
Being stuck up here where i have no other go to reconfigure a new nagiosxi. :oops:
mguthrie
Post by mguthrie »
This will get you what you need.
service mysqld stop
myisamchk -r -f *.MYI
John12
Post by John12 »
HI,
Thanks for the reply.
I executed the commands.. and it did some fixing on records...
but as usual my service panel is empty.
below is the screenhost.
I can see the services on nagioscore and i am getting alerts on mail.
Pls help. what else i need to do..
awaiting response. :(
Lets run the following for a few minutes to see if there are any other database table errors
  • tail -f /var/log/mysql.log
John12
Post by John12 »
hi..
I monitored mysqld log.. here is the screenshot.
what else.. Error is incorrect file format in tables.
regards,
John.
Do you have a backup of the nagios database from before this problem occured?
ls -l /store/backups/mysql/daily/nagios
John12
Post by John12 »
Hi ,
Sorry for late reply.
When i had the service Detail disappeared issue. I tried but lastly gave up and installed the nagiosxi VM again.
But now today i again got the service detail crashed error.. (screenshot attached)
But i followed.
service mysqld stop
It did fixed some tables.
and my service details were back. I don't know why same procedure not fixed the same problem which i had once before.
Any way.. NagiosXI works ok now for me. just FYI.
Thanks for great support.
John.
mguthrie
Post by mguthrie »
Glad it's working again. Since you're running this on Vmware Workstation, if you ever have to shutdown the XI VM, make sure to run:
shutdown -h now
From the VM's shell. Don't use Vmware Workstations "Power Off" option because you'll corrupt your database tables almost every time you do that. MySQL doesn't play nice with a hard power off.
John12
Post by John12 »
Thanks for the info.. i keep in mind.
