would you please provide the steps to shutdown the Nagiosxi server ? such as any stop service.
Ricky
shutdown VM Nagiosxi server steps
Re: shutdown VM Nagiosxi server steps
shutdown -r now to restart
shutdown -h now to halt
This is basic linux.
Hi kg2857,
is no need stop mysql \ postgresql before run shutdown -r now ?
Ricky
Ricky
Are you looking to shutdown nagios only or shutdown the vm itself in a whole? If you are shuting down as a whole you can do as kg suggested and everything should be fine. The only instances ive noticed of database issues is when a vm is turned off incorrectly, i.e. a power outage. We also have db restore scripts to help fix these issues. If you want to just shutdown everything correlated to nagiosxi you can use these commands (somethings might need to be different based on what distro you are using. i.e. httpd might be php-fpm):
service nagiosxi stop
service npcd stop
service ndo2db stop
service nagios stop
service postgresql stop
service mysqld stop
service httpd stop
Hope this helps
service npcd stop
service ndo2db stop
service nagios stop
service mysqld stop
service httpd stop
Hope this helps
You can use the command `service nagiosxi stop` (for CentOS/Debian) or `systemctl stop nagiosxi` (for systemd). This gracefully stops the Nagios XI service and its dependencies. wordle unlimited
The core Nagios service is `nagios`, so you should use or if you're trying to stop Nagios from running.
systemctl stop nagiosCode: Select all
service stop nagiosActively advancing awesome answers with ardent alliteration, aptly addressing all ambiguities. Amplify your acumen and avail our amicable assistance. Eagerly awaiting your astute assessments of our advice.
