How to clean-up huge list of "Not Sending" Unique Hosts
Haas07
Post by Haas07 »
Hi there,
I got myself in a bit of a mess...
Due to a wrong manipulation of a filter i ended up with a huge list of "Not Sending" Unique Hosts.
Reason is that i (briefly) used 'host' as the field name in a CSV filter.
I understand that this is a 'reserved word' and this mistake somehow made these entries tagged as input hosts.
There a few thousand entries, and I would like to avoid having to manually be clicking/deleting every single entry.
And my question is how i would be able to clean this out in a more convenient way?
Is there any location/file, or is there any command that i could run?
jmichaelson
Re: How to clean-up huge list of "Not Sending" Unique Hosts
Post by jmichaelson »
I'm not sure that there is an easy way to do what you're doing, that we provide. Could you be a bit more specific as to what you did to create that filter in the first place, and I can try to replicate the scenario and see if I can provide more guidance to easily handle this?
-Jason
Haas07
Post by Haas07 »
Hey Jason,
Thank you for your response already!
I'm not 100% sure anymore.
But i think i either used "host" as part of the CSV filter
if [host] == '##.##.##.##' {
csv {
columns => ["zs01_time","zs02_login","zs03_protocol","host","zs04_eurl","zs05_action"]
OR i might have done something like this where i created a new field named host.
#Copy a field
ruby {
code => "
event['host'] = event.get('FQDN15')
Regards
John
jmichaelson
I'm working on what hopefully will resolve this for you. Unfortunately Its going to be Monday before I can verify whether it will work.
-Jason
jmichaelson
Good morning! I just had to make sure that what I was going to have you do will regenerate the known hosts list. I'm not sure how long it will take but for me sometime between the time I left on Friday and now it regenerated so I feel safe having you do this. SSH into yout Log Server system, and at the shell prompt type the following:
curl -X "DELETE http://localhost:9200/nagioslogserver/cf_option/known_hosts"
This will delete the known hosts list, and the system jobs will eventually reset it.
Hope this helps you!
-Jason
Haas07
Post by Haas07 »
Hey Jason,
This worked!
Thank you very much man, you saved my mouse and my finger from developing RSI.......
Tiny note: I just had to move the double quote
curl -X DELETE "http://localhost:9200/nagioslogserver/c ... nown_hosts"
thank you!
John
jimmyjane
Post by jimmyjane »
jmichaelson wrote: Mon Feb 12, 2024 11:46 am Good morning! I just had to make sure that what I was going to have you do will regenerate the known hosts list. I'm not sure how long it will take but for me sometime between the time I left on Friday and now it regenerated so I feel safe having you do this. SSH into yout Log Server system, and at the shell prompt type the following:
Thank you, Jason, for the solution you provided. It worked perfectly for me as well, and it saved me a lot of time and effort. For anyone else facing the same problem, I recommend following Jason's advice to delete the known hosts list. Just remember to place the double quotes correctly around the URL like John mentioned
