Upgrade CentOS 7.9 to 9 in 4 instances of Nagios XI server
Post Reply
ignacio.sanchez
Post by ignacio.sanchez »
Hi all,
As you may know, CentOS 7 EOL will be on June 30, 2024, so we will need to upgrade our actual Nagios XI instances.
I already read the forums, and basically, an upgrade is not recommended and/or supported, so the better way of doing it is creating a new server.
And that's the point where I'm at.
I already created a new server using a Nagios XI OVA (nagiosxi-2024R1.0.1-64.ova), and then I followed the instructions in Nagios KB, that is:
The backup was completed successfully, but the import in the new server is failing every time.
1)
/usr/local/nagiosxi/scripts/restore_xi.sh /tmp/1707214089.tar.gz
2) It failed with the error:
ERROR: Could not connect to localhost:3306 with root password supplied.
Please enter the MySQL root password:
3) Added skip-grant-tables in MySQL config file (/etc/my.cnf.d/mysql-server.cnf)
4) The next error message is:
ERROR 2013 (HY000) at line 2244: Lost connection to MySQL server during query
Error restoring MySQL database 'nagios'
No matter what I do, it always fails with the same message (different line)
I tried adding the following to the MySQL config with no luck:
[mysqld]
connect_timeout=300
net_read_timeout=7200
net_write_timeout=7200
max_allowed_packet=512M
I even tried to import nagios.sql manually with the following command, but again, same error message:
cat /tmp/nagios.sql | mysql -u nagios -p'nagiosxi' -h "localhost" nagios
ERROR 2013 (HY000) at line 494: Lost connection to MySQL server during query
Can you please let me know what else can I try?
Thank you!
gwesterman
Re: Upgrade CentOS 7.9 to 9 in 4 instances of Nagios XI server
Post by gwesterman »
Hi @ignacio.sanchez,
Is the version of XI you are restoring from the same as the one you are restoring to (i.e. is the server on CentOS 7 also 2024R1.0.1)? In order for the backup and restore process to work properly, the two versions need to be the same and you can upgrade XI once the restore has been completed.
ignacio.sanchez
gwesterman wrote: Thu Feb 08, 2024 10:12 am Hi @ignacio.sanchez,
Hi @gwesterman,
Yes, both servers are in 2024R1.0.1, and the backup was made on that version too.
ignacio.sanchez
Hi all,
Do you know if there is a better method to migrate the servers or should I open a support ticket directly?
Thank you!
gwesterman
Sorry for the delay. I have not seen this error during migration before and I cannot find another instance of it happening to someone else. For quick resolution, I would suggest opening a support ticket at the Answer Hub. But, I will leave this thread open if I or someone else can find something helpful in the meantime.
Thank you!
bekean23
Post by bekean23 »
gwesterman wrote: Wed Feb 14, 2024 10:03 am Hi @ignacio.sanchez, subway surfers
Sorry for the delay. I have not seen this error during migration before and I cannot find another instance of it happening to someone else. For quick resolution, I would suggest opening a support ticket at the But, I will leave this thread open if I or someone else can find something helpful in the meantime.
Thank you!
I got it, thanks!
willie34
Post by willie34 »
you must migrate to a fresh installation of CentOS Stream 9 Geometry Dash Lite (or an alternative like Rocky Linux 9 or AlmaLinux 9) and then reinstall/configure Nagios XI.
Post Reply
