Monitor Memory Win Server dude
Post Reply
rambertnala
Post by rambertnala »
Hi friends.
Is there any way to monitor used memory las 15 minutes.???
I need to know if there is any plugin to get critical when used memory last 15 minutes is 100%
I do not know is this is posible
Thanks and regards
lgute
Re: Monitor Memory Win Server dude
Post by lgute »
Hi @rambertnala, thanks for reaching out.
You can set the max_check_attempts and retry_interval to catch this type of situation.
For example, if you do not want to know about a condition until it is a problem for 15 minutes, you can set the following.
max_check_attempts    3
retry_interval        5
The service will be checked at five-minute intervals and go to SOFT ERROR, and then at the 3rd "failed" check (3 * 5 mins = 15 mins), it will go to a HARD ERROR and notify.
If you want to check more frequently, you can also change the retry_interval.
-Laura
Post Reply
