Single instance vs. cluster
Post Reply
randy-ringnalda
Post by randy-ringnalda »
I currently have a single instance Nagios Log Server but unless I keep the indexes pruned it has serious performance issues.
Currently there are 80 hosts but only like or so send a lot of logs to the system.
Would it work better to have a cluster rather than a single instance?
jmichaelson
Re: Single instance vs. cluster
Post by jmichaelson »
Depending on how powerful your server is, you may want to upgrade it, or alternatively, yes, adding nodes is an option.
-Jason
jsimon
Post by jsimon »
To add on to @jmichaelson 's response, we strongly recommend having at least two instances in a cluster to ensure redundancy and avoid data loss.
cnorell
Developer
Post by cnorell »
To add on even more: ideally in different geographic locations.
Post Reply
