Nagiosxi adons tools
shirishlnx
Post by shirishlnx »
Hi Team,
One of our client want an GUI based tool for configuration changes to NRDS config files like check boxes etc .
Can you please help to know, is it possible tools like nconf etc .. to integrate with Nagiosxi .
Any other suggestions are welcome .
Shirish
Re: Nagiosxi adons tools
This is on the roadmap for NRDS but development hasn't started yet.
shirishlnx
Can we integrate any opensource tools like Nag2web, nconf, NagiosAdmin etc. with Nagiosxi to achieve the same .
Is nagiosxi allows opensource tools to get integrated with it ?
Shirish
I'm not exactly sure how you would use those with NRDS, but Nagios is built to be very flexible. You can build your own components to be added into the system
http://library.nagios.com/library/produ ... evelopment
shirishlnx
Thanks .
