Unable to Access GUI
Post Reply
randy-ringnalda
Post by randy-ringnalda »
I am unable to get the Apache HTTP service to start.
[root@nagiosxinorth ~]# systemctl status httpd.service
× httpd.service - The Apache HTTP Server
Loaded: loaded (/usr/lib/systemd/system/httpd.service; enabled; preset: disabled)
Drop-In: /usr/lib/systemd/system/httpd.service.d
└─php-fpm.conf
Active: failed (Result: exit-code) since Tue 2024-03-05 07:21:40 CST; 6min ago
Docs: man:httpd.service(8)
Process: 1132 ExecStart=/usr/sbin/httpd $OPTIONS -DFOREGROUND (code=exited, status=1/FAILURE)
Main PID: 1132 (code=exited, status=1/FAILURE)
Status: "Reading configuration..."
CPU: 73ms
randy-ringnalda
Re: Unable to Access GUI
This is something that just happened without any updates to the system except DNS
sgardil
Post by sgardil »
Hey @randy-ringnalda
Do you happen to have a snapshot of before upgrading the DNS? Or do you recall if this issue started happening as soon as there was any changes to the DNS? You could check the httpd.conf file to see if there are any changes made/missing from the changes to the DNS.
randy-ringnalda
I think actually that the issue happened before any IP address/DNS was changed.
swolf
Developer
Post by swolf »
Hi @randy-ringnalda,
I think you will want to look into your systemd and apache logs to try and troubleshoot. If you're not able to get on track with that information, I would recommend opening a case on Answer Hub, so that our Support Engineers can help troubleshoot your environment directly.
Developer @ Nagios 2017-05-15 thru 2024-08-06
Post Reply
