Issue with NRPE: Invalid packet version received
Post Reply
fanis_imetrix
Post by fanis_imetrix »
I'm encountering an issue with NRPE on my setup. When I try to execute the check_updates command remotely using NRPE, I receive the following error message:
CHECK_NRPE: Invalid packet version received from server.
The command (check_updates) returned an invalid return code: -196608|
Could you please provide guidance on how to resolve this issue? Any help would be greatly appreciated.
Thank you!
sgardil
Re: Issue with NRPE: Invalid packet version received
Post by sgardil »
Hey @fanis_imetrix
Is this happening after upgrading your Xi? It seems like for a quick fix, a lot of users had success modifying the check_nrpe command to use -2 as an argument. I'll link another thread that has had a pretty thorough talk about this issue if you would like to take a look.
viewtopic.php?t=60566
onsccwg833
Post by onsccwg833 »
fanis_imetrix wrote: Wed Mar 06, 2024 11:01 am Hello,
The command (check_updates) returned an invalid return code: -196608| Slope Game
Thank you!
2
I am trying to monitor a small service on a dummy server via Icinga2 the check_nrpe plugin. I have setup both correctly as I can do the following:
when I run /usr/lib/nagios/plugins/check_nrpe -H remote-server-ip from the main server I get NRPE v2.15
when I do /usr/lib/nagios/plugins/check_nrpe -H main-server-ip from the remote server I get the same result.
when I run /usr/lib/nagios/plugins/check_nrpe -H remote-server-ip -c
check_load I get WARNING - load average: 5.85, 5.67, 5.55|load1=5.850;15.000;30.000;0; load5=5.670;10.000;25.000;0; load15=5.550;5.000;20.000;0;
sgardil
Post by sgardil »
Hey @onsccwg853
Could you clarify if you are also having the same issue as above. Also if so have you tried the quick fix mentioned above and it didnt work?
Post Reply
