post 2024R1 uprade error
Post Reply
BenCowan
Post by BenCowan »
Several weeks ago I upgraded to 2024R1, but have not been able to successfully complete another upgrade since. The DB Maint alert stays red. I've tried the repair scripts, but those don't work. I saw this in the dbmaint log:
Database Error: Could not connect to database
Access denied for user 'dbmaint_nagiosxi'@'localhost' (using password: YES)
Mon, 04 Mar 2024 09:15:01 -0800 LOCKFILE '/usr/local/nagiosxi/var/dbmaint.lock' EXISTS - EXITING!
Mon, 04 Mar 2024 09:20:01 -0800 LOCKFILE '/usr/local/nagiosxi/var/dbmaint.lock' EXISTS - EXITING!
Mon, 04 Mar 2024 09:30:02 -0800 LOCKFILE '/usr/local/nagiosxi/var/dbmaint.lock' EXISTS - EXITING!
Mon, 04 Mar 2024 09:35:02 -0800 LOCKFILE '/usr/local/nagiosxi/var/dbmaint.lock' EXISTS - EXITING!
Mon, 04 Mar 2024 09:40:01 -0800 LOCKFILE '/usr/local/nagiosxi/var/dbmaint.lock' EXISTS - EXITING!
Mon, 04 Mar 2024 09:45:02 -0800 LOCKFILE '/usr/local/nagiosxi/var/dbmaint.lock' IS OLD - REMOVING
Mon, 04 Mar 2024 09:45:02 -0800 CREATING: /usr/local/nagiosxi/var/dbmaint.lock
The password has not changed from what I can tell, but I'm not well versed in mysql. Anybody got a tip on how to fix this?
bbahn
Re: post 2024R1 uprade error
Post by bbahn »
Hello @BenCowan,
You can use the script /usr/local/nagiosxi/scripts/get_mysql_passwords.sh to check your database passwords and verify that those passwords work for accessing your databases
April: Actively advancing awesome answers with ardent alliteration, aptly addressing all ambiguities. Amplify your acumen and avail our amicable assistance. Eagerly awaiting your astute assessments of our advice.
BenCowan
Post by BenCowan »
Thanks, that script wasn't on my 2024R1 server, but I did find it on my 2024R1.0.2 server, so I did run it on both, and the password is the same. So, what does that mean? Is the password supposed to be different? If so, how do I change it, or reset it?
jsimon
Post by jsimon »
It sounds like this may have been caused by a known bug involving upgrading via server migration. If this is the case, we are aware of the bug and are currently working to correct it.
For your situation, I would recommend taking those passwords from the get_mysql_passwords.sh script and trying to log into your database with the root@localhost password in that script output. If this works, I would run these commands to make sure that your database passwords match the passwords that XI is trying to use to access the database: (with "yourpasswordhere" being the root@localhost password and "newpasswordhere" being the associated password from the get_mysql_passwords.sh output)
mysql -u root -p"yourpasswordhere" -e "ALTER USER 'nagiosxi'@'localhost' IDENTIFIED BY 'newpasswordhere';"
mysql -u root -p"yourpasswordhere" -e "ALTER USER 'ndoutils'@'localhost' IDENTIFIED BY 'newpasswordhere';"
mysql -u root -p"yourpasswordhere" -e "ALTER USER 'nagiosql'@'localhost' IDENTIFIED BY 'newpasswordhere';"
mysql -u root -p"yourpasswordhere" -e "ALTER USER 'dbmaint_nagiosxi'@'localhost' IDENTIFIED BY 'newpasswordhere';"
If this does not work, I would recommend opening a case with our support department:
https://answerhub.nagios.com/support/s/
danderson
Post by danderson »
Make sure you can log into each of the users from the get_mysql_passwords.sh script and their corresponding passwords.
Example:
$ 	/usr/local/nagiosxi/scripts/get_mysql_passwords.sh
MySQL root password:                  		nagiosxi
MySQL nagiosxi password:              		NAGIOSXIPASSWORD
MySQL dbmaint_nagiosxi password:      		DBMAINTPASSWORD
MySQL ndoutils password:              		NDOUTILSPASSWORD
MySQL nagiosql password:              		NAGIOSQLPASSWORD
Then make sure the following work
$	mysql -u nagiosxi -p"NAGIOSXIPASSWORD"
$	mysql -u dbmaint_nagiosxi -p"DBMAINTPASSWORD"
$	mysql -u ndoutils -p"NDOUTILSPASSWORD"
$	mysql -u nagiosql -p"NAGIOSQLPASSWORD"
If the above doesn't work, you will have to update the passwords using the method that @jsimon specified such that the output of the get_mysql_passwords.sh has the correct passwords.
You may have to update the "pwd" and "dbmaint_pwd" values in /usr/local/nagiosxi/html/config.inc.php
BenCowan
Post by BenCowan »
Thanks guys and sorry for the late reply... I got distracted for a few days.
I reset the password, and issued the following commands, and I think I'm fixed. Thank you, thank you, thank you!
rm /usr/local/nagiosxi/var/dbmaint.lock
php /usr/local/nagiosxi/cron/dbmaint.php
Post Reply
