Nagios Core Not Updating With *.cfg file updates
wneville
Post by wneville »
I have a Nagios Core installation that is accepting passive checks from a few remote servers. I am now attempting to create a service which will monitor the nagios process on the localhost. Here is my service definition in /usr/local/nagios/etc/objects/localhost.cfg:
    host_name               localhost
    service_description     nagios_service_status
    check_command           check_local_procs!1:!nagios!
    max_check_attempts      2
    check_interval          5
    retry_interval          5
    check_period            24x7
    active_checks_enabled   1
    notification_interval   60
    notification_options    w,c,r
    contact_groups          moogsoftadmins
    notifications_enabled   1
    notification_period     24x7
Here is the command being called by the service:
    command_name    check_local_procs
    command_line    $USER1$/check_procs -c $ARG1$ -C $ARG2$ $ARG3$
When we run systemctl restart nagios.service, the service titled 'nagios_service_status' never shows up. Can anyone help me troubleshoot why this might be happening? (or not happening..... :lol: )
danderson
Re: Nagios Core Not Updating With *.cfg file updates
Post by danderson »
Thanks for reaching out @wneville,
Are there any errors within journalctl -xeu nagios.service when you restart nagios?
wneville
Post by wneville »
Thanks so much for your help. Here is the output:
Mar 11 13:45:31 [servername_redacted] nagios[4747]: PASSIVE SERVICE CHECK: [remoteserver1];Swap Usage;0;OK: Swap usage was 0.00 % (Used: 0.0
Mar 11 13:45:31 [servername_redacted] nagios[4747]: PASSIVE SERVICE CHECK: [remoteserver1];Memory Usage;0;OK: Memory usage was 57.40 % (Avai
Mar 11 13:45:31 [servername_redacted] nagios[4747]: PASSIVE SERVICE CHECK: [remoteserver1];Process Count;0;OK: Process count was 115
Mar 11 13:45:51 [servername_redacted] nagios[4747]: PASSIVE SERVICE CHECK: [remoteserver2];Disk Usage;0;OK: Free was 178.90 GiB
Mar 11 13:45:51 [servername_redacted] nagios[4747]: PASSIVE SERVICE CHECK: [remoteserver2];CPU Usage;0;OK: Percent was 0.00 %
Mar 11 13:45:51 [servername_redacted] nagios[4747]: PASSIVE SERVICE CHECK: [remoteserver2];Swap Usage;0;OK: Swap usage was 0.00 % (Used: 0
Mar 11 13:45:51 [servername_redacted] nagios[4747]: PASSIVE SERVICE CHECK: [remoteserver2];Memory Usage;0;OK: Memory usage was 24.40 % (Av
Mar 11 13:45:51 [servername_redacted] nagios[4747]: PASSIVE SERVICE CHECK: [remoteserver2];Process Count;0;OK: Process count was 129
Mar 11 13:45:58 [servername_redacted] systemd[1]: Stopping Nagios Core 4.4.14...
-- Subject: Unit nagios.service has begun shutting down
-- Defined-By: systemd
-- Support: http://lists.freedesktop.org/mailman/listinfo/systemd-devel
-- Unit nagios.service has begun shutting down.
Mar 11 13:45:58 [servername_redacted] nagios[4747]: Caught SIGTERM, shutting down...
Mar 11 13:45:58 [servername_redacted] nagios[4747]: Successfully shutdown... (PID=4747)
Mar 11 13:45:58 [servername_redacted] systemd[1]: Stopped Nagios Core 4.4.14.
-- Subject: Unit nagios.service has finished shutting down
-- Unit nagios.service has finished shutting down.
Mar 11 13:45:58 [servername_redacted] systemd[1]: Starting Nagios Core 4.4.14...
-- Subject: Unit nagios.service has begun start-up
-- Unit nagios.service has begun starting up.
Mar 11 13:45:58 [servername_redacted] nagios[29223]: Nagios Core 4.4.14
Mar 11 13:45:58 [servername_redacted] nagios[29223]: Copyright (c) 2009-present Nagios Core Development Team and Community Contributors
Mar 11 13:45:58 [servername_redacted] nagios[29223]: Copyright (c) 1999-2009 Ethan Galstad
Mar 11 13:45:58 [servername_redacted] nagios[29223]: Last Modified: 2023-08-01
Mar 11 13:45:58 [servername_redacted] nagios[29223]: License: GPL
Mar 11 13:45:58 [servername_redacted] nagios[29223]: Website: https://www.nagios.org
Mar 11 13:45:58 [servername_redacted] nagios[29223]: Reading configuration data...
Mar 11 13:45:58 [servername_redacted] nagios[29223]: Read main config file okay...
Mar 11 13:45:58 [servername_redacted] nagios[29223]: Read object config files okay...
Mar 11 13:45:58 [servername_redacted] nagios[29223]: Running pre-flight check on configuration data...
Mar 11 13:45:58 [servername_redacted] nagios[29223]: Checking objects...
Mar 11 13:45:58 [servername_redacted] nagios[29223]: Checked 90 services.
Mar 11 13:45:58 [servername_redacted] nagios[29223]: Checked 17 hosts.
Mar 11 13:45:58 [servername_redacted] nagios[29223]: Checked 3 host groups.
Mar 11 13:45:58 [servername_redacted] nagios[29223]: Checked 0 service groups.
Mar 11 13:45:58 [servername_redacted] nagios[29223]: Checked 2 contacts.
Mar 11 13:45:58 [servername_redacted] nagios[29223]: Checked 2 contact groups.
Mar 11 13:45:58 [servername_redacted] nagios[29223]: Checked 29 commands.
Mar 11 13:45:58 [servername_redacted] nagios[29223]: Checked 5 time periods.
Mar 11 13:45:58 [servername_redacted] nagios[29223]: Checked 0 host escalations.
Mar 11 13:45:58 [servername_redacted] nagios[29223]: Checked 0 service escalations.
Mar 11 13:45:58 [servername_redacted] nagios[29223]: Checking for circular paths...
Mar 11 13:45:58 [servername_redacted] nagios[29223]: Checked 0 service dependencies
Mar 11 13:45:58 [servername_redacted] nagios[29223]: Checked 0 host dependencies
Mar 11 13:45:58 [servername_redacted] nagios[29223]: Checked 5 timeperiods
Mar 11 13:45:58 [servername_redacted] nagios[29223]: Checking global event handlers...
Mar 11 13:45:58 [servername_redacted] nagios[29223]: Checking obsessive compulsive processor commands...
Mar 11 13:45:58 [servername_redacted] nagios[29223]: Checking misc settings...
Mar 11 13:45:58 [servername_redacted] nagios[29223]: Total Warnings: 0
Mar 11 13:45:58 [servername_redacted] nagios[29223]: Total Errors:   0
Mar 11 13:45:58 [servername_redacted] nagios[29223]: Things look okay - No serious problems were detected during the pre-flight check
Mar 11 13:45:58 [servername_redacted] nagios[29231]: Nagios 4.4.14 starting... (PID=29231)
Mar 11 13:45:58 [servername_redacted] systemd[1]: Started Nagios Core 4.4.14.
-- Subject: Unit nagios.service has finished start-up
-- Unit nagios.service has finished starting up.
-- The start-up result is done.
Mar 11 13:45:58 [servername_redacted] nagios[29231]: Local time is Mon Mar 11 13:45:58 EDT 2024
Mar 11 13:45:58 [servername_redacted] nagios[29231]: LOG VERSION: 2.0
Mar 11 13:45:58 [servername_redacted] nagios[29231]: qh: Socket '/usr/local/nagios/var/rw/nagios.qh' successfully initialized
Mar 11 13:45:58 [servername_redacted] nagios[29231]: qh: core query handler registered
Mar 11 13:45:58 [servername_redacted] nagios[29231]: qh: echo service query handler registered
Mar 11 13:45:58 [servername_redacted] nagios[29231]: qh: help for the query handler registered
Mar 11 13:45:58 [servername_redacted] nagios[29231]: wproc: Successfully registered manager as @wproc with query handler
Mar 11 13:45:58 [servername_redacted] nagios[29231]: wproc: Registry request: name=Core Worker 29232;pid=29232
Mar 11 13:45:58 [servername_redacted] nagios[29231]: wproc: Registry request: name=Core Worker 29234;pid=29234
Mar 11 13:45:58 [servername_redacted] nagios[29231]: wproc: Registry request: name=Core Worker 29235;pid=29235
Mar 11 13:45:58 [servername_redacted] nagios[29231]: wproc: Registry request: name=Core Worker 29233;pid=29233
Mar 11 13:45:58 [servername_redacted] nagios[29231]: Warning: Could not open object cache file '/usr/local/nagios/var/objects.cache' for writing!
Mar 11 13:45:58 [servername_redacted] nagios[29231]: Successfully launched command file worker with pid 29236
wneville
Post by wneville »
Good Morning @danderson - any ideas here? There were no errors in the journalctl output as noted in my last post
lgute
Post by lgute »
Hi @wneville, thanks for reaching out.
Core should installed with a check command called "check_local_procs", with...
check_command	check_local_procs!250!400!RSZDT
    command_line    $USER1$/check_procs -w $ARG1$ -c $ARG2$ -s $ARG3$
Unless you overwrote that original command, you probably need to change the name of your new command to something else, for example check_local_procs_service_status.
-Laura
wneville
Post by wneville »
You can close this thread. The issue was that someone or something had edited the objects.cache file, which changed the file's owner to a user that didn't exist. After that, the application was trying to write the new objects to the objects.cache file but failing
Changing the objects.cache owner allowed the new services to be picked up when the nagios service was restarted
Thank you so much for your time and effort, I really really appreciate it!
lgute
Post by lgute »
Hi @wneville,
Thank you for the update.
-Laura
