Hi Team,
We are continuously facing issues related to Nagios Logs getting disappeared.
As a workaround we to run below commands. However we need help with permanent fix
***Command to start and stop Nagios services***
Stop
systemctl stop elasticsearch
systemctl stop logstash
systemctl stop httpd
==wait for 5-10 min === Start
systemctl start elasticsearch
systemctl start logstash
systemctl start httpd
Our current Nagios Log Server version is 2.1.6
Please suggest, quick response will be highly appreciated.
Nagios Logs Keep disappearing
Re: Nagios Logs Keep disappearing
Thanks for reaching out @veerendra.patial,
Just to clarify, the logs will sometimes disappear, and when you restart those services the logs reappear?
- jmichaelson
As an add-on, can you also provide system information? RAM, Disc space, RAM and disc usage.
If you can find any relevant data in /var/log/elasticsearch that would be helpful as well (i.e., is elasticsearch crashing?)
-Jason
-Jason
