check_xi_oraclequery doesn't work!!!
Post Reply
BICE
Post by BICE »
Hi all,
We are trying this check from Nagios XI 5.11.3:
check_xi_oraclequery!--connect=<CONN> --user=<USER> --password=<PASS> --mode=sql --name="select count(*) from TABLE where gls_tipo_pago='V' and cod=60 and exp_date=to_char(sysdate, 'dd-mm-yyyy') and oper_date=to_char(sysdate, 'dd-mm-yyyy')" --critical @1
And we're not getting any result or error message.
This SQL query works just fine in SQLDeveloper or SQLPlus...
We appreciate any help
gwesterman
Re: check_xi_oraclequery doesn't work!!!
Post by gwesterman »
Hi @BICE,
Have you tried running the plugin from the command line? What happens when you try that?
BICE
Post by BICE »
Yes, We got this UNKNOWN message:
UNKNOWN - got no valid response for select count(*) from TABLE where gls_tipo_pago='V' and cod=60 and exp_date=to_char(sysdate, 'dd-mm-yyyy') and oper_date=to_char(sysdate, 'dd-mm-yyyy') - ORA-00942: table or view does not exist (DBD ERROR: error possibly near <*> indicator at char 21 in ' SELECT version FROM <*>v$instance ')
We tried the check without this part of query--> 'and exp_date=to_char(sysdate, 'dd-mm-yyyy') and oper_date=to_char(sysdate, 'dd-mm-yyyy')' and the plugin returns a value successfully...
But we need is to be able to execute the full query.
cnorell
Developer
Post by cnorell »
Did this query work in the past, or did you recently add this check to Nagios XI?
BICE
Post by BICE »
@cnorell
this is a brand new check that we need...
Post Reply
