way to save columns view
scheived
Post by scheived »
How to save the Columns you have chosen in the Table settings?
I've gone to configure, Panel, add/remove Columns but every time I go back to query search it's back to the default view of columns, is there a way to save the view?
scheived
Re: way to save columns view
Post by scheived »
Ah I guess if I save the dashboard it saves the columns then.
jsimon
Post by jsimon »
Hi @scheived,
It sounds like you were able to resolve your question. Do you need any further assistance? Otherwise I can lock this topic.
