vSphere Plugin (BETA) - required software components missin
Post Reply
Nuggel1234
Post by Nuggel1234 »
I wanted to try the new vsphere plugin and executed the commands in the documentation:
python3 -m pip install --upgrade pip
python3 -m pip install --upgrade setuptools wheel
python3 -m pip install --upgrade pyvmomi
I get:
-bash: pyhton3: command not found
Any ideas?
bbahn
Re: vSphere Plugin (BETA) - required software components missin
Post by bbahn »
Hello @Nuggel1234,
You can install Python 3 by using your package manager (dnf/yum on CentOS/RHEL/Oracle, apt/apt-get on Debian/Ubuntu) to install Python 3 with
[package-manager] install python3
or by upgrading Nagios XI.
kvang
Post by kvang »
Hi Nuggel1234,
I am not sure how your machine was set up but you can also try running the following commands to see if python is detected.
python --version
which python
or
python3 --version
which python3
If it looks like it is installed you can always check your path environment variables...see link
sgardil
Post by sgardil »
Hey @Nuggel1234
Did manually installing python 3 like mentioned above solve the issue for you? If so we can close this thread.
Post Reply
