Nagios Core 4.4.5 Just not Starting
ATIAdmin
Post by ATIAdmin »
Hi all, first time poster here, hope I have the right part of the forum.
I am running Red Hat 8 (on AWS) and installed Nagios following the steps here (https://access.redhat.com/documentation ... figuration) and the installation went smoothly. Although, when I get to "2.2. Starting the Nagios Core service" I am unable to get the Nagios service to start and seemingly there are no errors being reported.
When I run the "pre-flight check" I get the following;
Nagios Core 4.4.5
Last Modified: 2019-08-20
License: GPL
Reading configuration data...
Read main config file okay...
Checking objects...
Checked 8 services.
Checked 1 hosts.
Checked 1 host groups.
Checked 0 service groups.
Checked 1 contacts.
Checked 1 contact groups.
Checked 24 commands.
Checked 5 time periods.
Checked 0 host escalations.
Checked 1 hosts
Checked 0 host dependencies
Checked 5 timeperiods
Checking misc settings...
Total Warnings: 0
Total Errors: 0
Then I try and start Nagios service and I get the following;
systemctl start nagios.serviceex
service nagios status
Redirecting to /bin/systemctl status nagios.service
● nagios.service - Nagios Core 4.4.5
Loaded: loaded (/usr/lib/systemd/system/nagios.service; enabled; vendor preset: disabled)
Active: failed (Result: exit-code) since Thu 2024-04-04 10:11:22 UTC; 10s ago
Docs: https://www.nagios.org/documentation
Process: 5221 ExecStopPost=/bin/rm -f /usr/local/nagios/var/rw/nagios.cmd (code=exited, status=0/SUCCESS)
Process: 5217 ExecStart=/usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg (code=exited, status=0/SUCCESS)
Process: 5216 ExecStartPre=/usr/local/nagios/bin/nagios -v /usr/local/nagios/etc/nagios.cfg (code=exited, status=0/SUCCESS)
Main PID: 5219 (code=exited, status=1/FAILURE)
Apr 04 10:11:22 ip-172-30-0-105.eu-west-1.compute.internal nagios[5216]: Checked 5 timeperiods
Apr 04 10:11:22 ip-172-30-0-105.eu-west-1.compute.internal nagios[5216]: Checking global event handlers...
Apr 04 10:11:22 ip-172-30-0-105.eu-west-1.compute.internal nagios[5216]: Checking obsessive compulsive processor commands...
Apr 04 10:11:22 ip-172-30-0-105.eu-west-1.compute.internal nagios[5216]: Checking misc settings...
Apr 04 10:11:22 ip-172-30-0-105.eu-west-1.compute.internal nagios[5216]: Total Warnings: 0
Apr 04 10:11:22 ip-172-30-0-105.eu-west-1.compute.internal nagios[5216]: Total Errors: 0
Apr 04 10:11:22 ip-172-30-0-105.eu-west-1.compute.internal nagios[5216]: Things look okay - No serious problems were detected during the pre-flight check
Apr 04 10:11:22 ip-172-30-0-105.eu-west-1.compute.internal systemd[1]: Started Nagios Core 4.4.5.
Apr 04 10:11:22 ip-172-30-0-105.eu-west-1.compute.internal systemd[1]: nagios.service: Main process exited, code=exited, status=1/FAILURE
Apr 04 10:11:22 ip-172-30-0-105.eu-west-1.compute.internal systemd[1]: nagios.service: Failed with result 'exit-code'.
I am doing all the above as su.
My Linux/Red Hat knowledge is limited and I am really banging my head against a wall here, any help would be greatly apricated.
gwesterman
Re: Nagios Core 4.4.5 Just not Starting
Post by gwesterman »
Hi @ATIAdmin,
Could you run "systemctl status nagios.service" and "journalctl -n" after trying to start the service and provide us the output?
Thank you!
ATIAdmin
Post by ATIAdmin »
Please see below;
Loaded: loaded (/usr/lib/systemd/system/nagios.service; enabled; vendor pres>
Active: failed (Result: exit-code) since Fri 2024-04-05 15:18:59 UTC; 13s ago
Process: 37140 ExecStopPost=/bin/rm -f /usr/local/nagios/var/rw/nagios.cmd (c>
Process: 37136 ExecStart=/usr/local/nagios/bin/nagios -d /usr/local/nagios/et>
Process: 37135 ExecStartPre=/usr/local/nagios/bin/nagios -v /usr/local/nagios>
Main PID: 37138 (code=exited, status=1/FAILURE)
nagios[37135]: Total>
Thing>
systemd[1]: Started >
Nagio>
Local>
LOG V>
qh: F>
Error>
nagios.s>
nagios.s>
lines 1-19/19 (END)...skipping...
Process: 37140 ExecStopPost=/bin/rm -f /usr/local/nagios/var/rw/nagios.cmd (code=exited, status=0/SUCCESS)
Process: 37136 ExecStart=/usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg (code=exited, status=0/SUCCESS)
Process: 37135 ExecStartPre=/usr/local/nagios/bin/nagios -v /usr/local/nagios/etc/nagios.cfg (code=exited, status=0/SUCCESS)
Total Errors: 0
Nagios 4.4.5 starting... (PID=37138)
Local time is Fri Apr 05 15:18:59 UTC 2024
LOG VERSION: 2.0
qh: Failed to init socket '/usr/local/nagios/var/rw/nagios.qh'. bind() failed: No such file or directory
Error: Failed to initialize query handler. Aborting
journalctl -n
-- Logs begin at Thu 2024-04-04 07:39:37 UTC, end at Fri 2024-04-05 15:19:02 UTC. --
nagios[37138]: qh: Failed to init socket '/usr/local/nagios/var/rw/nagios.qh'. bind() failed: No such file or directory
nagios[37138]: Error: Failed to initialize query handler. Aborting
systemd[1]: Started Session 3821 of user ec2-user.
systemd[1]: Started Session 3822 of user root.
CROND[37146]: (root) CMD (/usr/bin/php /var/www/atiprod/moodle/admin/cli/cron.php >/dev/null)
CROND[37147]: (ec2-user) CMD (/usr/bin/php /var/www/atiprod/moodle/admin/cli/cron.php >/dev/null)
systemd[1]: session-3814.scope: Succeeded.
systemd[1]: session-3815.scope: Succeeded.
gwesterman
Hi @ATIAdmin,
It looks like the issue is with this file:
Check if it exists and verify whether or not it is owned but nagios:nagcmd. There are also a number of potential solutions if you search the error that includes that file (from this forum even!), but I recommend snapshotting your server before trying them.
ATIAdmin
Post by ATIAdmin »
Apologies for the delay in replying I was away.
The file you have stated does not exist.
ATIAdmin
Post by ATIAdmin »
I have upgraded to Nagios Core 4.5.1 and still getting the same messages and the same file is missing
bbahn
Post by bbahn »
@ATIAdmin,
Have you ran
cd /
find -name "nagios.qh"
It seems at some point several configuration files moved locations for Nagios Core and this may have something to do with your current issues. If you do find it somewhere else, you can move or copy it over to the /usr/local/nagios/var/rw/ location.
ATIAdmin
Post by ATIAdmin »
I have been unable to find "nagios.qh" so somehow it seems like it did not get installed at all
gwesterman
Do you have the folder /usr/local/nagios/var/rw/?
If not, you might be able to just make it and set the permissions.
Start by snapshotting your server. Then run:
mkdir -p  /usr/local/nagios/var/rw/
chmown nagios:nagcmd /usr/local/nagios/var/rw/
systemctl restart nagios
Let us know if this works and if you need help with anything else.
Thank you!
ATIAdmin
Post by ATIAdmin »
IT WORKED gwesterman! The Nagios service is running, I did have to modify one of the command:
chown nagios:nagcmd /usr/local/nagios/var/rw/
As I got the error message; chown: invalid group: ‘nagios:nagcmd’
I just ran this command instead:
chown nagios:nagios /usr/local/nagios/var/rw/
