Offloaded Database moving back to Local?
Post Reply
TBT
Post by TBT »
Our Nagios Databases are offloaded, and over the years there have been one or two comments within support tickets that we may want to consider moving the Databases back locally to the XI Servers.
Primarily, the concern is bugs and or oversights in relation to XI upgrades with offloaded DBs. Though these historically have been infrequent, they have occurred (even recently) and could potentially be avoided if our Databases were local again.
We have several XI servers, and the amount of checks varies. An XI server monitoring the least has 28 Hosts+44 Services, mid-range is 374 Hosts+2710 Services, and the largest 1591 Hosts+7692 Services. We are not experiencing performance issues, but based on the number of checks, at what point should the Nagios Databases be local again, or should it be kept offloaded?
Nagios XI 2024R2.2.1 (8 Servers)
Nagios Fusion 2024R1.0.2
jsimon
Re: Offloaded Database moving back to Local?
Post by jsimon »
Hi @TBT,
Generally you are probably better off having local databases simply because you avoid the extra points of failure they add without adding significant upside. Network issues between your XI server and your databases can occur which can affect monitoring or cause engine issues, and differences between your database and your Nagios engine can cause DB corruption. With modern hardware I don't know that there's a specific database size or host count where you should begin to make changes, but our best practice recommendation would be to use local databases for Nagios products.
TBT
Post by TBT »
@jsimon thank you for the insight, I'll take this into consideration prior to our next XI upgrade.
otisjame
Post by otisjame »
TBT wrote: Wed Apr 10, 2024 9:10 am Our Nagios Databases are offloaded, and over the years there have been one or two comments within support tickets that we may want to consider moving the Databases back locally to the XI Servers.
I'm really waiting for the answer
sgardil
Post by sgardil »
otisjame wrote: Tue Jun 04, 2024 8:57 pm
TBT wrote: Wed Apr 10, 2024 9:10 am Our Nagios Databases are offloaded, and over the years there have been one or two comments within support tickets that strands nyt we may want to consider moving the Databases back locally to the XI Servers.
Hey @otisjame
unfortunately if you are curious about the performance issues with varying sizes of offloaded systems we can't really give you a real answer because it is dependent on the hardware that is being used. Like jsimon mentioned the larger concern would be the network connection issues and how that can affect your monitoring.
bekean23
Post by bekean23 »
sgardil wrote: Wed Jun 05, 2024 9:41 am
We have several XI servers, and the amount of checks varies. An XI server monitoring the least has 28 Hosts+44 Services, mid-range is 374 Hosts+2710 Services, and the largest 1591 Hosts+7692 Slither Services. We are not experiencing performance issues, but based on the number of checks, at what point should the Nagios Databases be local again, or should it be kept offloaded?
Hey @otisjame
Thank you for explaining it to me!
Post Reply
