Hello!
I need to set Autocomplete off in GUI login, by a security issue indicated by our Security Department.
Can anyone help me?
Thanks in advance
Juancholp
Note: NagiosXI 5.10.0
Autocomplete set to off
gwesterman
Re: Autocomplete set to off
Hi @bergna,
There is the option to disable autocompletion for sensitive fields under Admin -> System Config -> System Settings -> General -> "Autocomplete Sensitive Fields".
Let us know if this works for you and if you have any other questions,
Thank you!
Thank you!
Thanks @gwesterman!!!
This solution is working OK!!!
Best Regards!!!
Best Regards!!!
mimef83807
Thanks. It worksgwesterman wrote: ↑Thu Apr 18, 2024 9:08 am Hi @bergna,
Let us know if this works for you and if you have any other questions, duck life
Thank you!
