I am trying to create a parent / child relationship map in Nagvis, but although my map has a root host and is displaying correctly, I also have some children with more parents than just the one in the map, these parents, are now being shown on the map. I've tried changing parentLayers and childLayers, with no luck.
Basically, what I need, is on a parent / child automap with a root host, to show me all the parents that might be related to a child of the root host.
Any ideas?
Kind Regards,
George
2 Parents, 1 host in Nagvis
helgaella99
Re: 2 Parents, 1 host in Nagvis
It sounds like you're tackling a complex issue with the parent/child relationships in Nagvis. It seems you've already experimented with parentLayers and childLayers to no avail. One approach you might consider is to check if there's a way to manually define or override the automatic relationships in the automap settings. Sometimes specifying explicit relationships or using filtering options in the Drift Hunters configuration can help control which elements appear on the map. Also, consider reaching out on forums or communities specific to Nagvis; other users might have encountered similar challenges and could offer a workaround.
