check_http error
Post Reply
vinmansbrew
check_http error
Post by vinmansbrew »
Ran into an issue with the check_http plugin.
/usr/local/nagios/libexec/check_http -H "website.com"
No route to host
HTTP CRITICAL - Unable to open TCP socket
If I take out the website name, and put in the IP, it works.
HTTP OK: HTTP/1.1 301 Moved Permanently - 299 bytes in 0.375 second response time |time=0.374855s;;;0.000000 size=299B;;;0
It had been working, but the server needed to be upgraded. It was rhel 6.10, it's sitting on rhel 7.9, for now, but will get moved to 8.9 soon.
Still using iptables, though I'll probably change it to firewalld. Ntp checks in ok.
I don't have an issue using the IP, other than if the IP changes in the future. So, this is mostly academic.
Thanks!
bbahn
Re: check_http error
Post by bbahn »
@vinmansbrew,
It would seem you are likely having an issue with DNS if the website name doesn't work, but the IP address does. Try running dig or nslookup with the "website.com". If it returns the IP address, then you know DNS is working and if not, then it isn't.
You can also try using ping on another website and its IP address to see if it's a more general issue
i.e.
ping 8.8.8.8
ping google.com
vinmansbrew
Well, I can dig and nslookup, so dns should be ok.
I didn't think that would be the issue, since it resolved fine, before the upgrade from rhel 6 to 7.
Core version is 4.5. I supposed it could just be a plugin config. Not entirely sure how to check plugin version.
peterjon
Post by peterjon »
Yes I Facing Thise Problem
jelambe24
Post by jelambe24 »
Let me ask, we are expecting 200s and OK when following a redirect, but instead, with the config set up for, example: check_http!-S!--sni -H admin-cmu.xras.org -u /login (returns a 302) and # check_command check_http!-S!--sni -H hostbame-I [ip address] -u /public/requests/1
# check_command check_https! --sni -H https://hostname -u /public/requests/1 -f follow if I run the same order of flags in the command from the command_line, I get 200s. is this what is normal, or is there a bug? I have tried ALL kinds of variations on the command check in the CFG to get the 200, but to no avail. Thoughts?
Post Reply
