Starting a Linux process only if it isn't started
Post Reply
bbahn
Re: Starting a Linux process only if it isn't started
Post by bbahn »
Hello @drewdavis,
You can definitely accomplish what you're thinking of using something like the following:
# Check if Nagios is running with /etc/init.d/nagios status, pgrep, systemctl status, ps aux | grep, etc.
# $? holds the exit status of the last command
if [ $? -ne 0 ]; then
    echo "Nagios is not running. Starting Nagios..."
    /etc/init.d/nagios start
else
    echo "Nagios is already running."
fi
Post Reply
