repair database issue
JohnFLi
Post by JohnFLi »
I ran:
awk '/"nagiosxi" => array\(/{getline;print}' /usr/local/nagiosxi/html/config.inc.php
it returned: "dbtype" => 'mysql',
then i ran:
/usr/local/nagiosxi/scripts/repair_databases.sh
all was good except for 1 item
myisamchk: error: 'nagios_systemcommands' is not a MyISAM-table
i ran
mysqlcheck -f -r -u root -pnagiosxi --all-databases
all was good except:
nagios.nagios_statehistory                         OK
nagios.nagios_systemcommands
Error    : Incorrect file format 'nagios_systemcommands'
error    : Corrupt
nagios.nagios_timedeventqueue                      OK
nagios.nagios_timedevents                          OK
how do I fix this?
Everybody is somebody else’s weirdo
JohnFLi
Re: repair database issue
Post by JohnFLi »
I found teh fix for this...it was in Nagios documentation already
https://assets.nagios.com/downloads/nag ... tabase.pdf
on page 4 it says:
If you receive an error, similar to this one:
error : Corrupt
You will need to execute the following command to fix the table:
service mysqld start
echo 'repair table nagios_systemcommands use_frm;' | mysql -t -u root -pnagiosxi nagios
service mysqld restart
Then check the log file for errors
When I tried to start the service, i was told
# service mysqld start
Redirecting to /bin/systemctl start mysqld.service
Failed to start mysqld.service: Unit not found.
ran the command anyway:
The result:
| Table                        | Op     | Msg_type | Msg_text |
| nagios.nagios_systemcommands | repair | status   | OK       |
tried the restart
Redirecting to /bin/systemctl restart mysqld.service
Failed to restart mysqld.service: Unit not found.
so I ran the original repair anyway
and now:
REPAIR COMPLETE
nagios database repair succeeded
nagiosql database repair succeeded
nagiosxi database repair succeeded
gwesterman
Post by gwesterman »
Glad you found the solution!
Let us know if you have any other questions.
Thank you!
