the exact error is
could not generate node_uuid - check file permissions
I have created a new centos stream9 to join the existing cluster and i had tested this in the lab and ran into the same issue
Am I wrong or is there a file that says you are only allowed 1 node which will stop you from joining the cluster?
I have read all the previous posts and tried the mv /usr/local/nagioslogserver/var/node_uuid /usr/local/nagioslogserver/var/node_uuid.old
systemctl restart elasticsearch but still same issue thanks in advance
Connect to existing cluster - could not generate node_uuid
Re: Connect to existing cluster - could not generate node_uuid
i gave a static ip and hostname rebooted and it now connects to existing cluster
- jmichaelson
When you were attempting to join to an existing cluster were you doing that from the initial screen at http://ip.address/nagioslogserver/install, after doing the fullinstall command? Or someplace else. I'm trying to figure out where the relevant issue should be written. Thanks much!
-Jason
-Jason
