NCPA Powershell Plugin trouble passing arguments
Post Reply
rfaulkner99
Post by rfaulkner99 »
I am having trouble passing parameters using a custom powershell plugin from a Windows machine running the NCPA 3.0.0.client.
To help with testing, I wrote the following PS script:
param (
[string]$F='John',
[string]$L='Doe',
[string]$M='E'
write-host "Success! $($F) $($M) modified $($L)."
Exit 0
Then, I try passing parameters, initially with Powershell named parameters like -F Joe -L Donuts, but that didn't work at all. Eventually I settled on using positional parameters, but have had issues getting that to work as well.
To test, I am modifying the nrdp.cfg on the Windows machine, restarting the service and then going to http://localhost:5693/gui/checks.
I have tried lots of combinations with varying results. For example:
%HOSTNAME%|TestArgs = plugins/testargs.ps1 --args Joe Donuts S"
returns Joe E Doe
Here are some of my notes, sorry they are a little disorganized. Keep in mind F used to be First, M - Middle, L - Last
-a did not work
--args 'G K B' not working at all
--args 'G,K,B' treats as first argument only
--args '-First G' not working
--args '--First G' not working
--args "-First G" not working
--args "-First 'G'"
--args -First G - specify a system string
--args -First "G" - Same
--args -First 'G' - Same
--args 'G','k' recognized first two params, but included quotes
--args Gar,k combined into 1 parameter.
--args "Gar ak","k" not working at all - Same with single quotes - doesn't seem to like spaces.
Gar,F,Eild - combined
"Gar","F","Eild" - correclty set first to "Gar" but combimed "F","Eild" together for last
"Gar,F,Eild" - combined into first
bbahn
Re: NCPA Powershell Plugin trouble passing arguments
Post by bbahn »
Hello @rfaulkner99,
For your PowerShell script to process the arguments correctly, you want the CLI input to be
plugins/plugin.ps1 "arg1" "arg2" "arg3"
To get this behavior as a passive check, you can use
%HOSTNAME%|TEST = plugins/test.ps1 --args "arg1" --args "arg2" --args "arg3"
You can more intuitively figure out how to properly configure your plugin inputs by first going through the NCPA UI at https://your_NCPA_ip_address:5693/gui/api/ and selecting plugins and pluginname.ps1 and then entering your arguments into the argument box and adding arguments as necessary until you get your desired result.
rfaulkner99
Thanks! That got me further, and the API tip makes testing much easier.
The only thing I am stuck on now is getting it to pass a path with a space. Powershell expects it to be wrapped in quotes, but I have tried double-quoting and using \ as an escape character and neither work.
bbahn
Post by bbahn »
That is a bug that should be fixed in NCPA 3.1.0.
rfaulkner99
OK, thanks for the information. Also, passing multiple arguments in a passive check using:
did not work for me either. When I do that, it only passes the last argument (arg3).
Is that also a bug?
bbahn
Post by bbahn »
This will work correctly in NCPA 3.1.0, which is scheduled to release very soon.
rfaulkner99
Almost everything seems to be working now with 3.1 except passing double quotes to arguments. I need to pass double quotes to a powershell -path argument - the path has a space and powershell requires it to be wrapped in double quotes - when I pass the argument it passes it with escape characters as show below. This is using the local API in the web gui.
powershell -ExecutionPolicy Bypass -File C:\\Program Files\\Nagios\\NCPA\\plugins\\check_release_args.ps1 -path '\"F:\\My Folder\\Backup\\Logs\\Release\"' -maxage 24 -filter *.*
Please let me know if there is another way to pass double quotes to the command line argument.
jmichaelson
Post by jmichaelson »
Where did you get the check_release_args script from? is it possible to modify it to handle the escaped quote? As a workaround, it may be possible to use the legacy 8.3 file name (as shown by doing a dir /X in a command prompt) for the directory and bypass the quotes, until we can come up with a better solution.
-Jason
rfaulkner99
I wrote the script. I just tried adding some code to mitigate the issue, but it is not working. Here is the code I added, which works from powershell if I feed it a similar looking escaped path. I commented above the line that I added
$path = '\"F:\\Special Apps\\Backup\\Logs\\Release\"'
#below is the line I added
$path=($path -replace '\\"','')
$filter="*.*"
If ($Path -like '*\') {$LogFilePath = $Path + $Filter}
Else {$LogFilePath = $Path + "\" + $Filter}
$Files=gci $logfilepath
And here is the error I get when running from the web API.
    "returncode": 2,
    "stdout": "\"F:\\Special Apps\\Backup\\Logs\\Release\"\n\"F:\\Special Apps\\Backup\\Logs\\Release\"\ngci : Cannot find drive. A drive with the name '\"F' does not exist.\nAt C:\\Program Files\\Nagios\\NCPA\\plugins\\check_release_args.ps1:17 char:8\n+ $Files=gci $logfilepath\n+        ~~~~~~~~~~~~~~~~\n    + CategoryInfo          : ObjectNotFound: (\"F:String) [Get-ChildItem], Dri \n   veNotFoundException\n    + FullyQualifiedErrorId : DriveNotFound,Microsoft.PowerShell.Commands.GetC \n   hildItemCommand\n \ngci : Cannot find drive. A drive with the name '\"F' does not exist.\nAt C:\\Program Files\\Nagios\\NCPA\\plugins\\check_release_args.ps1:19 char:11\n+ $LastFile=gci $logfilepath| sort lastwritetime | select -last 1\n+           ~~~~~~~~~~~~~~~~\n    + CategoryInfo          : ObjectNotFound: (\"F:String) [Get-ChildItem], Dri \n   veNotFoundException\n    + FullyQualifiedErrorId : DriveNotFound,Microsoft.PowerShell.Commands.GetC \n   hildItemCommand\n \nError! 0 files considered, no files match *.*.",
    "cmd": "powershell -ExecutionPolicy Bypass -File C:\\Program Files\\Nagios\\NCPA\\plugins\\check_release_args.ps1 \"F:\\Special Apps\\Backup\\Logs\\Release\""
bbahn
Post by bbahn »
@rfaulkner, it seems your issue is that your wrapping of the path in quotes is breaking your plugin.
I see a few methods to handle this:
  1. Use single quotes
  2. Have your script convert the escaped double quotes to unescaped double quotes (($path -replace '\"', '"'))
Post Reply
