SNMP trap for Dell hardware
Post Reply
CPSMY_BSP_Build
Post by CPSMY_BSP_Build »
I would like to raise a support on setting up for SNMP trap on our monitoring. We have configure in the Nagios but it seems does not push the alert from Dell hardware to the nagios.
kg2857
Re: SNMP trap for Dell hardware
Post by kg2857 »
Did you set the nagios hosts as the trap reciever on the dell host?
CPSMY_BSP_Build
May I know the procedure to perform the set up?
kg2857
Post by kg2857 »
How to set it up is in Dell's documentation. You just set the nagios hosts as a destination, etc. You can probably figure it out w/o docs.
Post Reply
