IP Address Manager
Post Reply
sawdusty
IP Address Manager
Post by sawdusty »
It doesn't appear that Nagios has an address manager built in similar to the address manager included with Solarwinds. Is anyone aware of an open source program that Nagios supports with a plugin? I didn't see anything in the Nagios Exchange.
sgardil
Re: IP Address Manager
Post by sgardil »
Hey @sawdusty
The Exchange would be the place to look for a third party plugin so it's unfortunate that there wasnt anything there. Could you go over exactly what you are looking for this plugin to do and I can take a look if I can find anything. Otherwise if you are comfortable making a plugin yourself I'll link some documentation. Let us know if you have any luck.
https://nagios-plugins.org/doc/guidelines.html
kg2857
Post by kg2857 »
Silly question but what about IP addresses do you want to manage?
sawdusty
Post by sawdusty »
We're using 192.168.0.0/16 across our network. Looking for something to document what subnets are in use and on what devices they're being used on. There are a few of us doing network related tasks on the network and I'm looking for a tool other than a spreadsheet to keep all the subnets documented. Ideally it would have been built in Nagios and worked with icmp to verify a specific subnets use/location.
Post Reply
