Temperature Monitoring of HP Switch
Post Reply
mehmwt
Post by mehmwt »
I am trying to monitor the temperature on HP switch, for this reason i have defined the command and services as follow.
here is the command:
command_name check_snmp
command_line $USER1$/check_snmp -H 10.176.64.1 -o iso.3.6.1.2.1.99.1.1.1.4.25
here is the service:
use generic-service ; Inherit default values from a template
host_name oswitch00
service_description Temp
check_command check_snmp
but on my nagios core interface i have error:
(No output on stdout) stderr:
Moreover, i used this command to see check_snmp works manually or not:
./check_snmp -H 10.176.64.1 -C public -P 2c -o iso.3.6.1.2.1.99.1.1.1.4.25
but this gives me segmentation fault (core Dumped)
i am using nagios core version Nagios Core 4.4.13
ssunga
Re: Temperature Monitoring of HP Switch
Post by ssunga »
Hey there, @mehmwt!
Let's walk through some steps together.
Step 1: SNMP Configuration Check
Make sure SNMP is enabled on your HP switch and the community string "public" has the correct permissions.
Step 2: Reinstall `check_snmp` Plugin
Reinstall the plugin to ensure it's not corrupted:
sudo apt-get install --reinstall nagios-plugins-snmp
or on Centos:
sudo yum reinstall nagios-plugins-snmp
Step 3: SNMP Tool Validation
Let's see if we can fetch data from the switch using snmpwalk:
snmpwalk -v2c -c public 10.176.64.1 iso.3.6.1.2.1.99.1.1.1.4.25
If you get a response here, we're on the right track.
Step 4: Update Command Definition
Try updating the Nagios command definition to include the community string and SNMP version:
    command_line $USER1$/check_snmp -H $HOSTADDRESS$ -C public -P 2c -o $ARG1$
Step 5: Adjust Service Definition
Update your service definition to pass the OID as an argument:
    host_name oswitch00
    check_command check_snmp!iso.3.6.1.2.1.99.1.1.1.4.25
Step 6: Manual Command Test
Before we apply changes in Nagios, let's test the command manually to make sure it's working:
/usr/local/nagios/libexec/check_snmp -H 10.176.64.1 -C public -P 2c -o iso.3.6.1.2.1.99.1.1.1.4.25
Step 7: Enable Debugging
Enable debugging in Nagios by adding to `nagios.cfg`:
debug_level=32
debug_verbosity=2
Restart Nagios:
sudo service nagios restart
You can also do
tail -f /usr/local/nagios/var/nagios.log
To observe nagios logs.
Try these steps and let us know if it resolves the issue!
Post Reply
