sleep is set to 300 in nrdp.cfg and every 5 minutes in unconfigured objects the last seen gets updated for the host, Disk and CPU. It doesn't seem to be respecting the 3600 interval for CPU.
2 of XI5.6.14 Prod/DR/DEV - Nagios LogServer 2 Nodes
See my projects on the Exchange at BanditBBS - Also check out my Nagios stuff on my personal page at Bandit's Home and at github
Thanks for letting us know about this issue. I will file an issue on the NCPA github and will investigate it when I get time.
I have been unable to replicate this issue. Are you sure you restarted NCPA after configuring your passive interval and that you aren't just looking at how often the log is updated per check? The ncpa_passive.log will be updated every minute for each check, but it only sends at the specified intervals.
As I have been unable to replicate this issue, I will close the issue if I don't hear of anyone encountering this within two weeks.
