UPS device port changes from 80 to 443
Post Reply
ssantha1985
Post by ssantha1985 »
Dear team,
There is a requirement to change the port from 80 to 443 for few UPS devices which am getting this error message
if its port 80 then seeing this output
./check_http -H XXx.xxx.xxx.xxx -L -w 60 -c 120
<A HREF="http://xx.xx.xx.xx:80/" target="_blank">HTTP OK: HTTP/1.1 200 OK - 1961 bytes in 0.147 second response time </A>|time=0.147184s;60.000000;120.000000;0.000000 size=1961B;;;0
./check_http -H xx.xx.xx.xx -p 443 -L -w 60 -c 120
<A HREF="http://xx.xx.xx.xx:443/" target="_blank">HTTP CRITICAL - No data received from host
unable to pull the information and need guidance to update with correct parameter in check_http
Much appreciated if i could get an solution on this.
Thanks & Regards,
Santhanam Subramani
gwesterman
Re: UPS device port changes from 80 to 443
Post by gwesterman »
Hi @ssantha1985,
Port 443 is the default port used for HTTPS (SSL/TLS - enabled) traffic. Your requirement is probably to set up SSL/TLS on your server. Once it is configured, you can use the -S option in the plugin to connect via SSL/TLS.
You may also have to allow port 443 in your firewall.
Let us know if you need any more assistance.
Thank you!
ssantha1985
Dear gwesterman,
We are already configured SSL / TSL in our nagios Server and still am using this command to query the UPS devices which are communicating with 443 throwing the error like below.
/usr/lib64/nagios/plugins/check_http -H 10.12.7.245 -p 443 -L -w 60 -c 120 -S
<A HREF="https://10.12.7.245:443/" target="_blank">CRITICAL - Cannot make SSL connection.
I have followed the steps which mentioned here to generate the SSL / TSL certificate
https://support.nagios.com/kb/article/n ... acle_Linux
But still same issues only. much appreciated if i can get a exact steps to sort out the on going issues from nagios server
Thanks & Regards,
Santhanam
Thanks & Regards,
Santhanam Subramani
swolf
Post by swolf »
Hi @ssantha1985,
I don't think the linked article will help you with check_http - that article is more about configuring an HTTPS certificate for the Nagios Core web interface itself.
If you need a more detailed error, I would run check_http with the -v option - hopefully that will point you in a more useful direction. If you need us to help more directly with troubleshooting, I would open a case on Answer Hub.
-Sebastian
ssantha1985
Dear Sebastian,
/usr/lib64/nagios/plugins/check_http -vvv -p 443 -H 10.12.7.245 -L -w 60 -c 120 -sni
<A HREF="http://10.12.7.245:443/" target="_blank">POST / HTTP/1.1
User-Agent: check_http/v2.3.3 (nagios-plugins 2.3.3)
Connection: close
Host: 10.12.7.245:443
Accept: */*
/usr/lib64/nagios/plugins/check_http -vvv -p 443 -H 10.12.7.245 -L -w 60 -c 120 -S
SSL initialized
Thanks & Regards,
Santhanam Subramani
gwesterman
Hi @ssantha1985,
I would give some of the options discussed in this thread a try. If none of these work for you, let us know.
Thank you!
ssantha1985
Hi team,
I have tried the options which mentioned on this https://github.com/nagios-plugins/nagio ... issues/376
no luck and seeing the same error message.
Thanks & Regards,
Santhanam
Thanks & Regards,
Santhanam Subramani
jmichaelson
Post by jmichaelson »
Can you navigate to the https url in a browser window? If so do you get a warning about the SSL/TLS certificate being untrusted?
-Jason
Post Reply
