Nagios XI Installation error
Post Reply
patrickm1
Post by patrickm1 »
I'm trying to install Nagios LS on Ubuntu 22.04 without avail. I am getting this error. Although I'm able to reach the GUI interface even though the installation says it failed.
The following packages have unmet dependencies:
libharfbuzz-subset0 : Depends: libharfbuzz0b (>= 5.1.0) but 2.7.4-1ubuntu3.1 is to be installed
E: Unable to correct problems, you have held broken packages.
INSTALLATION ERROR!
in your communications with Nagios Enterprises technical support.
The step that failed was: 'backend'
bbahn
Re: Nagios XI Installation error
Post by bbahn »
Hello @patrickm1,
It seems you have some broken packages.
To begin with, I suggest running the following:
sudo apt update
sudo apt upgrade
After that, you can try manually installing the libharfbuzz0b package, check for held packages with sudo apt-mark showhold and try unholding them with sudo apt-mark unhold <package_name> and try fixing broken packages with sudo apt --fix-broken install
jmichaelson
Post by jmichaelson »
This is a result of a Debian package dependency change made after the product was released. We have a help document on the matter here:
https://answerhub.nagios.com/support/s/ ... and-Debian
-Jason
patrickm1
Post by patrickm1 »
I'm getting this error after running ./upgrade
cp: cannot create regular file '/usr/local/nagiosxi/var/': Not a directory
swolf
Post by swolf »
Hi @patrickm1,
Which product are you installing? From your opening post, it sounds like you're trying to set up Nagios Log Server on a new server, but the thread title and error suggest that you're trying to install Nagios XI.
-Sebastian
ssunga
Post by ssunga »
@patrickm1
Is it possible you're using the upgrade script from nagiosxi rather than Nagios Log Server? The lack of a `nagiosxi` directory suggests you may be trying to upgrade `nagioslogserver` instead.
I would run ls /usr/local to observe if I have `nagiosxi` or `nagioslogserver` and adjust accordingly.
Post Reply
