Invalid max_check_attempts after 2024R1.1.3 upgrade
Post Reply
Basher
Post by Basher »
I have two separate installations of Nagios XI, version 2024R1.1.3. After updating to the latest version, if I edit a host and leave max_check_attempts = 3, I receive the following error:
Error: Invalid max_check_attempts value for host '<hostname>'
If I update to 2 or 4, it applies successfully. If I change it back to 3, the error returns.
I believe this is a bug, as it worked in the previous version (2024R1.1.2). Am I missing something?
bbahn
Re: Invalid max_check_attempts after 2024R1.1.3 upgrade
Post by bbahn »
Hello @Basher,
This is very strange. I will do some investigation and file a bug for this.
bbahn
Post by bbahn »
This is getting fixed in 2024R1.1.4
Basher
Post by Basher »
Yep, saw this just now. Upgraded to 2024R1.1.4 and tested successfully.
Post Reply
