Nagios CORE commands failing from XI web interface
BenCowan
Post by BenCowan »
RHEL9 w/Nagios XI version 2024R1.1.4
I upgraded last week but just noticed that I was unable to issue commands via the web interface. For example Home->Tactical Overview->Notifications I' receive errors attempting to ENABLE/DISABLE anything. The following error was prevalent in the logs so I commented out a block of code (lines 315 to 320) and now it's working, however, I have no idea what I may have broken by doing this.
Mon, 08 Jul 2024 17:32:01 -0700 PROCESSED 0 COMMANDS
PHP Warning: Undefined array key "REQUEST_METHOD" in /app/nagios/nagiosxi/html/includes/utils.inc.php on line 315
............................................................PHP Warning: Undefined array key "REQUEST_METHOD" in /app/nagios/nagiosxi/html/includes/utils.inc.php on line 315
sgardil
Re: Nagios CORE commands failing from XI web interface
Post by sgardil »
BenCowan wrote: Mon Jul 08, 2024 7:56 pm RHEL9 w/Nagios XI version 2024R1.1.4
We use grab_request_vars in many locations so its best to not comment out this code. I'm not sure what your line 315 looks like but it seems like there isn't a guard for if that array key exists. If you want to get rid of the warning you mentioned above and you feel fine updating the code you can change line 315 to this:
    if (array_key_exists('REQUEST_METHOD', $_SERVER) && $_SERVER['REQUEST_METHOD'] == "PUT") {
Let us know if this fixes your issue.
BenCowan
Post by BenCowan »
That worked great. Thanks. Will that alternate code be in future upgrades?
bbahn
Post by bbahn »
@BenCowan,
Yes, this change will be included in future updates.
BenCowan
Post by BenCowan »
Excellent.
rosydam
Post by rosydam »
sgardil wrote: Tue Jul 09, 2024 9:18 am
BenCowan wrote: Mon Jul 08, 2024 7:56 pm RHEL9 w/Nagios XI version 2024R1.1.4Incredibox game
We use grab_request_vars in a many locations so its best to not comment out this code. I'm not sure what your line 315 looks like but it seems like there isn't a guard for if that array key exists. If you want to get rid of the warning you mentioned above and you feel fine updating the code you can change line 315 to this:
sgardil
Post by sgardil »
Hey @rosydam
I saw you quoted the response above. Are you still having similar issues?
Andreaa23
Post by Andreaa23 »
If Nagios CORE commands are failing when executed through the Nagios XI web interface, but work via the command line, it’s often related to permissions, configuration issues, or web interface settings. incredibox sprunki
cenat
Post by cenat »
That fix using array_key_exists really helped smooth things out,nulls brawl apk I had almost the same issue after the update. It’s a relief knowing the patch is coming in future releases. Saves a lot of time digging through code just to keep basic functions working.
kg2857
Post by kg2857 »
When running commands via the CCM they run as the apache user. When run from the shell, they run as the current user. When run via x they're x user. Test using valid test criteria.
Post Reply
